Latest post Thu, Apr 7 2016 6:08 PM by David Yardley. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Apr 7 2016 4:29 PM
    Question regarding Arri 2K 4:3 Anamorphic workflow to Avid 8.5.1?!?!
    Cheers fellow Aviders!. .. .I have this issue that I need to fix immediately, I’m not sure if it’s because I chose the wrong Project format, or transcoded the AMA links wrong.
    I’m working as a DIT/AE on a indie low budget feature.. . and we’re shooting with Arri 2K 4:3 2048x1536. .. Expected aspect ratio, 2.39.1
    I created a 2K 2048x1536 4:3 23.976 project in Avid 8, than did the frame flex on the linked Arri ProRes AMAs, set the image aspect ratio to 2.39.1. . Then I transcoded in Avid’s background and then made Stills from those transcodes for Production.
    but in Avid when I hit the full frame playback option, the frame leaves black bars on the sides and the DP of the project said the Stills came out a bit squeezed looking.
    My questions are, what do I to fix this issue immediately?!. . Where did I go wrong?. .. .I just wanna make sure I setup the right format settings for the project, so the Editor after me isn’t working with different aspect ratios.
    This is only the 2nd day on this Production and I wanna make sure to get a fast & smooth workflow going, and I’d really like to do all my work in Avid and not use a 3rd part software.
    Thank you all for reading my message, have a great day!
    On a late 2013 21.5 inch iMac with 2.9 Ghz Intel Core i5 Processor Upgraded NVIDIA GeForce GT 750M 1024 MB Graphics Card Memory 8 GB 1600 MHz DDR3 ... [view my complete system specs]
  • Thu, Apr 7 2016 6:08 PM In reply to
    Re: Question regarding Arri 2K 4:3 Anamorphic workflow to Avid 8.5.1?!?!
    Sebastian,
    I think you might be confusing screen aspect ratio with the pixel ratio needed to display the image correctly.
    See if this helps:
    http://www.arridigital.com/forum/index.php?topic=7604.0
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona 3. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 14GB ram Aja I/O express, Apple... [view my complete system specs]
