Latest post Thu, Mar 31 2016 7:06 AM by Jeroen van Eekeres. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Mar 31 2016 3:36 AM
    • Shelbytm22
    • Joined on Fri, Jun 6 2008
    • Arlington, VA
    • Posts 4
    • Points 40
    Avid CoreAudio.plugin & El Capitan Shutdown Problem
    Mac Pro (Late 2013), El Capitan (10.11.4) and using Avid MBox Pro...
    My Mac Pro would not shut down. Had to do a hard shut down every time until I found some helpful information online:
    http://avid.force.com/pkb/articles/en_US/troubleshooting/Unable-to-shut-down-or-restart-Mac-after-installing-HD-Driver
    Apparently El Capitan deos not like the Avid CoreAudio.plugin file located in /Library/Audio/Plug-Ins/HAL/. In order to get a proper shutdown, you have to remove the plugin file from the folder. The only problem with that, is that NOW you are unable to play any audio out of the MBox Pro.
    I now do the workaround and press cmd + spacebar, open activity monitor, and stop the "WindowServer" proccess. It will take you to your computer's login menu, from there go to "shutdown".
    Can anyone from Avid say when this will be fixed or if it is being looked into?
    Tim
    • Mac Pro (Late 2013)
    • 3 GHz 8-Core Intel Xeon E5
    • 64 GB 1866 MHz DDR3 ECC
    • AMD FirePro D700 6144 MB
    Mac Pro (Late 2013), OS X El Capitan 10.11.4 3GHz 8-Core Intel Xeon E5 64gb 1866 MHz DDR3 ECC Dual AMD FirePro D700 6144mb MBox Pro Media Composer... [view my complete system specs]
  • Thu, Mar 31 2016 7:06 AM In reply to
    Re: Avid CoreAudio.plugin & El Capitan Shutdown Problem
    Don't know if it is related but 10.11.4 is not supported yet. Only 10.11.3.
    See this post by Marianna.
    http://community.avid.com/forums/p/138371/785306.aspx
    Jeroen van Eekeres
    www.mediaoffline.com
