Latest post Thu, Apr 7 2016 7:43 PM by Kevin Klimek. 22 replies.
Page 1 of 2 (23 items) 1 2 Next >
  • Fri, Mar 4 2016 7:35 PM
    • JKL32
    • Joined on Sat, Dec 22 2007
    • The Netherlands
    • Posts 210
    • Points 2,945
    Cmd-P gives instant crash! (Print Bin or Timeline)
    When using the Print Bin or Print Timeline command with Cmd-P, Avid crashes instant. Without any warning or message. Using Page Setup from the File menu crashes Avid MC 8.5 also instantly.
    Do other users have this also?
    Avid Media Composer 8.6, BMD UltraStudio Mini Monitor(Desktop Video 10.8), New Mac Pro 8 core, D700, 64g RAM, El Capitan [view my complete system specs]
  • Fri, Mar 4 2016 8:12 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,840
    • Points 20,340
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Cmd-P gives instant crash! (Print Bin)
    Hello JKL32,
    JKL32:
    When using the Print Bin command with Cmd-P, Avid crashes instant. Without any warning or message. Using Page Setup from the File menu crashes Avid MC 8.5 also instantly.
      Does not happen to Windows. It crashes even with new project?
    Regards,
    Ralph
  • Fri, Mar 4 2016 8:31 PM In reply to
    • JKL32
    • The Netherlands
    • Posts 210
    • Points 2,945
    RalphC:
    Hello JKL32,
    JKL32:
    Regards,
    Ralph
    Yes, even with a new project.
  • Sat, Mar 5 2016 12:40 AM In reply to
    • Greg Cohan
    • Joined on Thu, Apr 9 2015
    • Hollywood
    • Posts 85
    • Points 990
    Just tested on one of our systems with command P and through menu and it is working fine.
    27 Systems all running MC 8.7 on OS 10.11.5, ISIS 5500 SD 4.7.4 client 4.7.7 [view my complete system specs]
  • Sat, Mar 5 2016 1:31 AM In reply to
    Wasn't there a thread not to long ago about some Mac's needing to have a Printer set as default or Avid might have problems?
  • Sat, Mar 5 2016 8:56 AM In reply to
    • JKL32
    • The Netherlands
    • Posts 210
    • Points 2,945
    AndrewAction:
    Found that thread and set my printer as default, but still crashes.
  • Sat, Mar 5 2016 8:57 AM In reply to
    • JKL32
    • The Netherlands
    • Posts 210
    • Points 2,945
    AndrewAction:
    Found that thread and set my printer as default, but it still crashes.
    Sorry for double post..!
  • Tue, Mar 8 2016 3:14 PM In reply to
    • RalphC
    • Posts 1,840
    • Points 20,340
      Avid Employee
    JKL32,
      The printer does not have issue with other program?
    Regards,
    Ralph
  • Tue, Mar 8 2016 6:39 PM In reply to
    • JKL32
    • The Netherlands
    • Posts 210
    • Points 2,945
    RalphC:
    JKL32,
    Regards,
    Ralph
    No issues at all. The printer is not even on, and if it is on, same thing happens; Avid quits faster than I can blink!
  • Fri, Mar 11 2016 3:54 PM In reply to
    • RalphC
    • Posts 1,840
    • Points 20,340
      Avid Employee
    JKL32:
    RalphC:
    Hello JKL32,
    JKL32:
    Regards,
    Ralph
    How about setting up a new profile/trashing settings.
  • Fri, Mar 11 2016 3:58 PM In reply to
    EDIT:
    It happened to me as well, but then I noticed that while I had a printer installed & selected, there was in fact no driver loaded. (This is a relatively new El Capitan install, and hadn't used the printer yet.)
    Once I had the driver, I was able to print a bin without issue.
  • Fri, Mar 11 2016 5:11 PM In reply to
    • RalphC
    • Posts 1,840
    • Points 20,340
      Avid Employee
    Thanks Kevin, forwading this to support.
    @JKL32 send me the crash logs, btw your in M.C. 8.5.1?
    Regards,
    Ralph
  • Fri, Mar 11 2016 5:58 PM In reply to
    • RalphC
    • Posts 1,840
    • Points 20,340
      Avid Employee
    Kevin Klimek:
    EDIT:
      Thanks for confirming this Kevin Yes
    @JKL32 check the driver and report back.
  • Fri, Mar 11 2016 6:22 PM In reply to
    • JKL32
    • The Netherlands
    • Posts 210
    • Points 2,945
    I have send it.
    I am on MC 8.5.1
  • Fri, Mar 11 2016 6:31 PM In reply to
    • RalphC
    • Posts 1,840
    • Points 20,340
      Avid Employee
    When replying, select "Options" to attach files. Did you check Kevin's comment about the driver?
    Regards,
    Ralph
