Latest post Tue, Apr 23 2019 12:02 AM by Job ter Burg. 4 replies.
  • Wed, Mar 2 2016 8:03 AM
    CTRL-X CTRL-V in timeline with MC 8.5 what happened?
    Upgrading to MC 8.5 did came with some changes. One is the changed behaviour of copy and paste in the timeline.
    Now CTRL-V does not "insert" the copied clip (moving the other clips in the timeline)  but overwrites in the time line.
    This is very annoying as I use this way of editing a lot.
    The upgrade came with a complete system install. Did a miss a setting?
    Thanks for helping
  • Wed, Mar 2 2016 8:24 AM In reply to
    Re: CTRL-X CTRL-V in timeline with MC 8.5 what happened?
    I just tried this on my 8.5 system and CTRL+V inserted the clip. I could make it overwrite by selecting the red (overwrite) arrow before pressing CTRL+V.  Maybe you could change the behavior by selecting the yellow (splice-in) arrow before pressing CTRL+V, and hopefully the behavior would "stick" afterward.
    Media Composer 2018.12.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Wed, Mar 2 2016 1:51 PM In reply to
    • Pixel Monkey
    • Posts 1,242
    • Points 15,695
    Yep. What Carl said.
    If it doesn't work automatically, try:
    Settings / Timeline Settings / Edit
    ... and change Default Segment Tool to the one you want.
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
    WWLD (What Would Larry Do?)
    WWND (What Would Norman Do?)
  • Mon, Apr 22 2019 9:08 PM In reply to
    • tbmcisp
    • Posts 31
    • Points 435
    I see this question is 3 years old with no answer.
    Ctrl + x and ctrl + V work differently depending on the avid I use.
    I have a desktop at work, laptop in the car and desktop at home.
    There must be a way to map the ctrl + v shortcut?
    where is there more info?
    I think it should work as it did for 25 years.
    that is;
    ctrl + X cuts the defined area on the timeline and closes the gap.
    ctrl + V inserts the defined area into the timeline at the new chosen spot,
    splicing it in.
    alt should  leave the space on X and overwrite with V.
    Currently the default is
    ctrl + X cuts and leaves a gap so have to ctrl + alt + V
    Ctrl + V overwites so have to ctrl + Alt + V to splice
    why?
    how can I fix this?
    help!!!
    It should work the sam as if your editing a word document.
  • Tue, Apr 23 2019 12:02 AM In reply to
    Hi, you are suggesting that on some systems, your Cut/Paste commands are doing like SpliceIns/Extracts, while on other systems, they are doing Overwrites/Lifts. And adding ALT reverses this behavior.
    I think you will find that you can change this, per system, by going into the Project Window, Settings, Timeline Settings, click the Edit tab, then below the middle, change the 'Default Segment Tool' setting to 'Segment Insert'.
    Chances are these settings differ on your different systems.
    As per Carl's and Chris' suggestions below.
    Timeline Settings
