Latest post Fri, May 6 2016 1:35 AM by phatratpak. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Mar 2 2016 12:09 AM
    • Swil
    • Australia
    • Posts 498
    • Points 6,495
    Clipboard in MC 8.5
    How do I get the "Clipboard Contents" action in the Source monitor back?
    The clipboard monitor is an interesting additional function, but it breaks the ability to copy from one place, extract something in the target destination to get it out of the way, and paste.
    Currently using the workaround of alt-ctrl-C, but it's just that, a workaround. The old system worked fine, I don't know why it's been removed.
    3.40GHz Core i7-2600K | 24Gb RAM | GeForce GTX 660 Ti | Blackmagic DeckLink Mini Monitor | Presonus AudioBox 22VSL | Windows 10 because I'm mad like... [view my complete system specs]
  • Wed, Mar 2 2016 1:10 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    Re: Clipboard in MC 8.5
    Swil:
    Yep - I'm left bemused - instead of being able to call up clipboard contents on the fast menu in the source window you now have to open a separate window. Why? WTFK's - if that's a workflow enhancement then someone at Avid needs to actually edit for a living.
    John
  • Wed, Mar 2 2016 2:34 AM In reply to
    • Hoh
    • Joined on Fri, Dec 23 2005
    • Ohio
    • Posts 207
    • Points 2,515
    You can assign the Clipboard Contents button to the Preview Monitor bar (if it isn't there already), then it is one click away.  The limitation here is that you only get the last thing that was copied to the clipboard.
    Load Clipboard Contents
    (1): Media Composer 2019.9 ∙ Windows 10 Pro ∙ HP Z840 Xeon E5-2620 v3 2.4GHz ∙ 64GB RAM HP Samsung DDR4 2133 ∙ NVIDIA Quadro K4200 385.69 ∙ BMD Intensity... [view my complete system specs]
  • Wed, Mar 2 2016 5:01 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    Yeah but why break something that wasn't broken..
    I put this one up there with having to multiple select audio keyframes acoss tracks. Used to be if you had the tracks selected you click on one keyframe you select them all at that timecode. Now you have to set an in and out or tediously control select individual audio keyframes. Its a pain in the a$$ and Avid have never fixed it or given an option to revert to the old behaviour.
    John
  • Wed, Mar 2 2016 5:25 AM In reply to
    • Hoh
    • Ohio
    • Posts 207
    • Points 2,515
    Oh, don't get me started on that Audio Keyframe debacle.  Talk about removing functionality and efficiency from editing.  ....Super Angry
  • Mon, Mar 7 2016 10:02 PM In reply to
    • Toby
    • Joined on Thu, Apr 4 2013
    • Los Angeles, California
    • Posts 68
    • Points 820
    AVID this is a joke. A very large network show has just switched to 8.5, and you can't load CLIPBOARD CONTENTS and there's no LOAD FILLER.
    WTF?
    PC tower: Intel Core i7-4790K @ 4Ghz. 32gb RAM. 64 bit Win10 Pro. Avid 2019 (as of Oct 2019). GTX 1070 Ti. [view my complete system specs]
    Mr TV Editor
  • Mon, Mar 7 2016 10:14 PM In reply to
    • bonang
    • Boston, MA
    • Posts 440
    • Points 5,520
    Right click on Source window for both.
    Avid MC 2021.12 with Symphony option | HP zbook 17" G3 / i7 6820HQ / 32GB RAM / 512GB SSD / WIN 10 PRO 64 / nVidia m3000m w/ 461.72 driver / BMD UltraStudio... [view my complete system specs]
    Keith
  • Mon, Mar 7 2016 10:18 PM In reply to
    Toby:
    Sure there is one place of several is click in Source monitor and it is the second item.  Under the timeline drop down menu you have add filler and two options "at start" and "at position"
    so they are both be mappable.  Load Filler is mappable from the Command palettes Menu to Button the it is a Menu Item in the Composer drop down menu
    Toby:
    CLIPBOARD CONTENTS
    Copy to clipboard and clipboard contents are both mappable to your KB or any button.
  • Fri, May 6 2016 1:35 AM In reply to
    • phatratpak
    • Los Angeles, CA
    • Posts 42
    • Points 440
    This is terrible.  So to confirm, there is no load clipboard contents into either monitor direct function?
    Additionally, I use the Segment Mode (red arrow) to lasso clips, copy them and then paste later in the sequence, this function is no longer available?
    Why were these changes made?
    Media Composer 5.5.3 / OSX 10.6.8 /MacBook Pro 17-inch 2.3GHz Quad-core Intel Core i7 / 8GB 1333MHz DDR3 SDRAM - 2x4GB / 500GB Serial ATA Drive @ 7200... [view my complete system specs]
