Latest post Fri, Feb 5 2016 9:03 PM by irwinpks. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Feb 5 2016 12:22 AM
    • irwinpks
    • Joined on Wed, Jun 22 2011
    • Posts 72
    • Points 840
    *** SOLVED *** How to De-activate license without being online. (Computer infected with Malware)
    Hello,
    My computer has been infected with Malware, and shutdown since. I'd like to de-activate the license so that I may reinstall after a reformat & reload of the operating system.  Would that require me to call in?  Trying to see if this can be done someway after Avid support hours (1-800-800-2843).
    Thank you,
    Irwin
    AVID Media Composer 8.5 / Windows 10 Pro 64-bit / Intel i7-3820 3.6ghz, 16gb RAM, AMD Radeon HD 7700, 256gb SSD (OS & App only), 512gb SSD (Media)... [view my complete system specs]
  • Fri, Feb 5 2016 12:05 PM In reply to
    Re: How to De-activate license without being online. (Computer infected with Malware)
    Normal 0 false false false EN-GB X-NONE X-NONE MicrosoftInternetExplorer4
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
    If you are re-installing on to the same machine then you should not have to un-install the licence.  The only gotcha is which network card you have as your default.  If you have manually chosen the Isis NIC as the primary NIC, then you will have to do the same on the rebuild for Avid licensing to see the MAC address of that card.  I have done this several times due to HDD failure and had no problems re-licensing with the on-line server.
    P.S. If you want to clean the spyware off your HDD without booting from it, use another PC, boot it up and then mount the infected drive on it using a caddy of some sort.  Then scan and delete the drive of any nasties.
    MC/SN 2018.6+7+8+9+12 x 16 Z400/420/440 PC's on W7 x64. 2 x Mac, 4 x PT 12.8.1 HDX, S6 all on PCs. [view my complete system specs]
  • Fri, Feb 5 2016 2:20 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,792
    • Points 19,770
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hello ShadenFreude,
          PM me your Avid Master account email and Systems ID, I will deactivate it for you.
    Regards,
    Ralph
  • Fri, Feb 5 2016 2:58 PM In reply to
    RalphC:
    Hello ShadenFreude,
    Regards,
    Ralph
    It's not me that needs the help btw.
  • Fri, Feb 5 2016 3:09 PM In reply to
    • RalphC
    • Posts 1,792
    • Points 19,770
      Avid Employee
    ShadenFreude:
    RalphC:
    Hello ShadenFreude,
    Regards,
    Ralph
     Sorry my fault Sad, I meant irwinpks.
  • Fri, Feb 5 2016 3:18 PM In reply to
    • irwinpks
    • Posts 72
    • Points 840
    ShadenFreude:
    It's the same machine, the nic will be the same too.
    ShadenFreude:
    This has already been done.  I've used Malwarebytes Anti-malware and several virus scanning software: Norton / McAfee / AVG.  The drive has been fully scoured.  However, just to be certain that nothing is there, it would be best not to connect to the Internet.  The malware was a trojan, the ripped my passwords from Google Chrome password manager.  I've since changed everything that I've ever logged into (anything that was worthwhile, like financial sites, etc.).
    At this point, I'm still not 100% convinced the software did a complete job, and it would be in my best interest to do a total wipe...and then I'll have full confidence of using the system again.
    Thank you ShadenFreude
  • Fri, Feb 5 2016 9:03 PM In reply to
    • irwinpks
    • Posts 72
    • Points 840
    Thank you everyone...it's all squared away.
