Latest post Thu, Jan 14 2016 3:04 PM by Ben Hills. 8 replies.
Page 1 of 1 (9 items)
  • Sun, Sep 13 2015 10:53 AM
    BUG - intermittent freezing MC 8.4.1
    New behavior that I've seen in MC 8.4.1, that wasn't in 8.4.0 - at times, after selecting some menu commands (entering the "export" dialog has been one), the entire system (aside from mouse movement) freezes - all input commands are delayed until things un-freeze.  System clock freezes.  A freeze can last about a minute.
    Seems somewhat random, no telling when it will or won't happen.
    Happens on my profile system 1, as well as at least one Mac Pro system at a workplace that's on OSX 10.9.5.
  • Sun, Sep 13 2015 3:23 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,427
    • Points 41,320
    Re: BUG - intermittent freezing MC 8.4.1
    See the following thread:
    http://community.avid.com/forums/t/134940.aspx?PageIndex=2
    As noted there I am getting the same sort of issues in 8.4.  Have not pushed to 8.4.1.  In fact, I have returned to 8.3.1 unless there is a specific need for 8.4.x.
    Mulitiple boot drives make that much more viable.
    Jef
    Jef Huey
  • Tue, Sep 15 2015 9:31 AM In reply to
    I'm not sure this is the same thing.  What i'm seeing appears completely new in 8.4.1.
    It seems to coincide with my first menu selection of an edit session.  A couple of times, it was Export.  At least once, it was Change Bin Color.  Another time, it was the "Set" button within the Export QuickTime Reference dialog..  But there seems to be a correleation with the first time a menu option is selected after starting the software.
    I've noticed this on my profile system 1 (OSX 10.10.5, MC 8.4.1, iMac), profile system 2 (OSX 10.9.5, MC 8.4.1, MBP 2009), and another non-profile system (Mac Pro 2008, OSX 10.9.5, MC 8.4.1).
  • Wed, Sep 16 2015 12:08 AM In reply to
    • jef
    • Maryland
    • Posts 3,427
    • Points 41,320
    Myabe not, but the symptoms are strikingly similar to the problem I am seeing that occurs with various activities in 8.4.  Something is up ...
    Jef
    Jef Huey
  • Wed, Jan 13 2016 7:27 PM In reply to
    Any update here?
    We are seeing random freezing with 8.4.4/8.4.5. We think it only occurs with 720p/59.94 based projects. But the sample size is too small to say definitively.
    z840 / 32GB / dual 1gE connections
    Windows 7 SP 1
    ISIS 4.7.7
  • Wed, Jan 13 2016 7:31 PM In reply to
    For what it's worth - the behavior I originally reported here seems to be fixed now.  I can't remember the last time it happened - 8.4.2 might have fixed it.
    jef's and Dom's may be a separate issue.
  • Wed, Jan 13 2016 8:05 PM In reply to
    • Posts 10,268
    • Points 218,980
    usatraveler:
    They did some tweaking and 8.4.2 and higher have better results so yes USA you are right.
    Jef and Dom....
    Can you be mroe specific what your issues are?
  • Wed, Jan 13 2016 9:44 PM In reply to
    The application will randomly lock up. Windows 7 remains fully functional. Other applications can be opened, used and closed without issues. After 4-8 min, MC will unlock. There are no errors in the MC Console, Fatal Error folder, Windows System Event Log or ISIS server side.
    It happens to both 720/60p based projects. The lone 1080i project has not crashed. We also noticed crashing when AMA + transcoding 720p with some media.
    We are testing with 8.3.1 now.
  • Thu, Jan 14 2016 3:04 PM In reply to
    • Ben Hills
    • Joined on Wed, Oct 17 2007
    • London, UK
    • Posts 30
    • Points 415
    Hi, we've been having something very similar in 8.4. Application freezes for roughly 2 - 5 minutes, but no errors/nothing in the console etc. You can even open a web browser behind and it works fine. We've had the same problem on 3 different Z800s, different specs, projects and users
    Bit of info:
    1080P 25 project
    DNxHD 36 (transcoded from Canon XF)
    Editshare storage only using about 60% of space on RAID + media space.
    It seems to get worse on larger projects.
    3 x HP z800 1 x HP z820 Avid MC 8.4 Windows 7 professional QT version 7.9.7 ----------------------------------- Edit Share Storage 64TB Thekus 12TB NAS... [view my complete system specs]
