Latest post Thu, Aug 13 2015 2:22 PM by Pat Horridge. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Aug 13 2015 9:21 AM
    Colour correction "through the day"
    I've been doing a series of timelapse drawings and the last one took so long it started at midday (high sun) and ended at night (with tungsten lighting casting green shadow).  Naturally, there will need to be several colour corrections.  I just wondered if CC can be keyframed, or something like?  In short, how to effect a gradualised/seamless colour correction operation in MC7?
    Thank you,
    DC
    Asus N55SF Notebook running Windows 10 Home Processor: Intel(R) Core (TM) i7-2670QM CPU @ 2.20GHz 2.20GHz Installed memory (RAM): 8.00 GB System type... [view my complete system specs]
  • Thu, Aug 13 2015 11:36 AM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,354
    • Points 16,655
    Re: Colour correction "through the day"
    You can't keyframe Avid CC effects, but you can use add-edits and dissolve between them either on the clip itself or on a filler track above.
    Alternately, some 3rd party CC tools such as Boris do allow for keyframing.
  • Thu, Aug 13 2015 12:27 PM In reply to
    You mean Keyframeable? If you say so:
    You can use the advanced keyframes interface in the Effect Editor to animate most color correction adjustments and You can:
    1. Manipulate many color correction parameters in the Effect Editor using sliders or parameter Enable buttons.
    2. Add and adjust keyframes for many color correction parameters in keyframe graphs, using the same methods you use for advanced keyframes in other effects.
    3. View keyframe markers in the position bar below the Current monitor in Color Correction mode.
    4. Automatically add keyframes by moving the position indicator below the Current monitor and then adjusting any keyframeable color correction parameter.
    5. Check how your animated color corrections are working by scrubbing through clips in Color Correction mode. Color correction parameter controls and graphs update as you scrub to show the parameter values at each point in the clip.
    cv
    AVID MEDIA COMPOSER 5.5.3. PC. WINDOWS 7, SP1. 64BIT OPERATING SYSTEM. QUICK TIME VERSION 7.6.9. [view my complete system specs]
    AVID USERS ECUADOR
    christianjhonsoon@hotmail.com
  • Thu, Aug 13 2015 12:41 PM In reply to
    Yes, you can keyframe all the CC parameters, but the downside is that if you copy the CC to another clip it will copy the animations with it, so it is often easier to use the add edit workflow.
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona 3. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 14GB ram Aja I/O express, Apple... [view my complete system specs]
  • Thu, Aug 13 2015 12:50 PM In reply to
    • Posts 10,079
    • Points 216,495
    David is spot on - and that downside has bit many in the butt in the past so just be careful.  I agree with davids suggestion.
  • Thu, Aug 13 2015 2:22 PM In reply to
    Make it monochrome and its all sorted :-)
    As long as the whole duration is within one clip you can keyframe the change over time. If you have multiple clips making up the sequence I'd mixdown to a flat single clip and CC that.
