Latest post Fri, Mar 16 2018 1:33 PM by Terry Snyder. 80 replies.
Page 2 of 6 (81 items) < Previous 1 2 3 4 5 Next > ... Last »
  • Wed, Apr 15 2015 5:49 PM In reply to
    • scocklin
    • Maryland
    • Posts 655
    • Points 7,855
    Re: Sorenson Squeeze codec problems between MainConcept & x264
    Do you mean Same as Source? This is how I do all of my mixdowns.
    HP Z800 2x 3.46GHz Hex Core X5690, 96GB Ram, Windows 10, Samsung SSD 850 Pro 512GB, Avid Mojo DX, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K,... [view my complete system specs]
  • Wed, Apr 15 2015 5:51 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    No custom exports , could you please do that described  mixdown and sas export for a test, I bet that it´s something wrong with either your project or workflow .
    Tomas
  • Wed, Apr 15 2015 5:52 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    scocklin:
    First mixdown and replace , then Same as Source
    Tomas
  • Wed, Apr 15 2015 5:54 PM In reply to
    • scocklin
    • Maryland
    • Posts 655
    • Points 7,855
    Thanks Thomas, I always mix down beforing exporting SAS, I have to add that the QT movie files compress fine on my Mac, the problem I'm having is with the Windows computer
  • Wed, Apr 15 2015 6:00 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    scocklin:
    Ok, thanks, it was a long run to get here.
    So we can exclude the workflow and bad files , time to check out other things as quicktime settings / versions and other codec stuff but that´ll be for tomorrow , other with good ideas might also chime in meanwhile.
    Tomas
  • Wed, Apr 15 2015 6:09 PM In reply to
    • scocklin
    • Maryland
    • Posts 655
    • Points 7,855
    Thanks very much for you help today Thomas, as for the set-up I used the PDF Avid HP Z800 configuration guide as a reference for setting up my Z800.
  • Wed, Apr 15 2015 6:12 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    My pleasure, I cannot see this as a hardware problem, it have to be codec / quicktime related somehow , I´m doing tons of x264 mp4 exports out of Squeeze using the above described workflow.
    If everything else fails I´ll send you one of my own customized mp4 profiles.
    Tomas
  • Wed, Apr 15 2015 6:15 PM In reply to
    • scocklin
    • Maryland
    • Posts 655
    • Points 7,855
    OK thank you!
  • Wed, Apr 15 2015 8:29 PM In reply to
    • Mark
    • Joined on Sun, Dec 19 2010
    • Posts 432
    • Points 4,660
    scocklin,
    To what specifications must your deliverable conform? Also, have you tried exporting QT ref from MC to Squeeze?
  • Wed, Apr 15 2015 9:49 PM In reply to
    • scocklin
    • Maryland
    • Posts 655
    • Points 7,855
    The final is an H.264, 1080p, QT Ref results in the same error.
  • Thu, Apr 16 2015 12:41 AM In reply to
    • Mark
    • Posts 432
    • Points 4,660
    Target application (web, DVD, etc)?
  • Thu, Apr 16 2015 3:52 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Two things came up in my mind during a good nights sleep.
    First, I have seen the 1:1 command for framerate in the videosettings " reading wrong " once or twice in the past so I always set it to the source framerate.
    Second, as you are a multi platform editor as myself ( I use Mac Drive Pro on PC and Mac formatted external drives ) you surely have your ways to share media between platforms.
    So, how does a PC sas export behave when encoding on the Mac and, contrary, does a Mac sas export encode better on PC .
    Those sas exports, are they all from DNx encoded mixdowns btw .
    add..  and a third idea , what happens if you manually adjust a preset to encode 1 pass cbr instead of the default 2 pass vbr
    Tomas
  • Thu, Apr 16 2015 11:18 AM In reply to
    • scocklin
    • Maryland
    • Posts 655
    • Points 7,855
    Hi Thomas, Yesterday I went back to what worked using x264, the 1280x720 setting on the youtube preset.  I tried it once again and it worked perfectly, I then adjusted the setting within the same preset to 1920x1080p and the error came up.
    Why would the larger raster on x264 fail
    I also tried youtube webM 1080p and it worked, MainConcept 1080p works.
  • Thu, Apr 16 2015 2:22 PM In reply to
    • Mark
    • Posts 432
    • Points 4,660
    Try Handbreak as long as it's free. It's also an X264 encoder. Even if it isn't a good permanent solution for you, you'll be able to determine if whatever is off is in the CODEC itself or Sorenson's implementaion of it.
  • Thu, Apr 16 2015 2:23 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Ok, great, so we are doing progress, try with some of my suggestions above and maybe also with another 1080 preset when you have the time, happy to send a 1080 preset myself but I think you should first test with another one of the default 1080 presets keeping it unchanged if possible.
    Tomas
