Latest post Fri, Apr 10 2015 8:11 PM by GregoAvid. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Apr 7 2015 3:38 PM
    • Gabriel
    • Joined on Wed, Dec 5 2012
    • Toronto
    • Posts 122
    • Points 1,400
    MC 8.3.1 no source monitor view
    Hi guys, yesterday I update to MC 8.3.1 and my source and preview monitors are stuck with the window that was prior, so if I wan t see footage doesn't show there.  I see the footage in my external Flanders monitor but not in the Avid interface source and preview little monitors.
    Any Idea
    PS: english is my second lenguage so maybe I didn't express properly my question. Sorry.
    Windows 7, 64bit
    AMC 8.3 Dell Precision T7610,Windows 7 Pro 64 bit, 512 SSD Drive (C Drive), 9TB Internal Raid 0, 4TB External Raid 1, 24 Core Intel Xeon CPU ES-2630 @ 2.60 GHz, 32 Gb ram, Quadro K5000, BMD Decklink SDI 4K Card. Asus ProArt 246Q, Asus ProArt 249Q & FSI LM-2461W.
  • Tue, Apr 7 2015 3:45 PM In reply to
    Re: MC 8.3.1 no source monitor view
    I had a similar problem and the solution was to use Avid's recommended NVidia drivers (340.84 I believe).
    MC|Software - Symphony 8.4.3, Win 8.1 Pro 64 HP ZBook 17, 32GB RAM, Quadro K5100M 8GB, Dreamcolor, Aja IO Express [view my complete system specs]
  • Wed, Apr 8 2015 1:43 AM In reply to
    • Gabriel
    • Toronto
    • Posts 122
    • Points 1,400
    Gracias Gustavo, tenias razon, era el driver, that's all.
    Thanks man, I downgraded the driver to 340.84 and done.
    Cheers
    GabrielSmile
    Filed under: ,
  • Wed, Apr 8 2015 3:42 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Hey,
    go to 'Console" and typ ein MonCon Off. My displays came back after using that command with teh newest Nvdia drivers.
    HP Z800 MC 8.3, Adobe CC, Windows 7 Ultimate 64-bit SP1, 2 Hex Core X5650 @ 2.67GHz, 48Gigs Ram, NVidia Quadro K4000, Sandisk Extreme 240 gig SSD System... [view my complete system specs]
  • Thu, Apr 9 2015 1:50 AM In reply to
    • Gabriel
    • Toronto
    • Posts 122
    • Points 1,400
    lunalobo75:
    Hey,
    I downgraded the nvivia drive already but thanks for the "MonCon Off";  a bit weird but if it works, works.
  • Fri, Apr 10 2015 8:11 PM In reply to
    • GregoAvid
    • Joined on Thu, Jul 26 2012
    • Posts 5
    • Points 50
    MonCon off works but patialy. Try hit 'L' key double or triple - display stays. However if you type MonCon on (after the off command). it works as should... strange...
    Regards
    Greg
