Latest post Fri, Apr 3 2015 10:33 AM by DedeS. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Apr 2 2015 3:21 PM
    • DedeS
    • Joined on Thu, Apr 2 2015
    • Posts 6
    • Points 80
    Unable to AMA link FS7 XAVC footage
    I run Media Composer 7.04, with the lates Sony AMA plug-in for XAVC files installed (PDZK-MA2 v3.40).
    I've received a hard drive with footage from the Sony FS7 in XAVC Intra 4K format. The clips are saved in a XDROOT\Clip folder, which I understands mirrors the folder structure on the camera's card.
    However, when I try to AMA link to the XDROOT folder, I receive the following error message: "AMA Manager - Failure accessing the volume information for volume F:\XDROOT\".
    And when I try to AMA link to the Clip folder, I receive the message: "Unable to link to any clips at F:\XDROOT\Clips".
    The error messages are the same regardless of whether I have 'Automatically AMA-link to volumes' in the AMA settings enabled or disabled.
    The Avid Editor Services are not running on my system (I've never been able to get them working), but this shoudln't affect AMA linking as it's for background services only and I'm able to AMA link files from other cameras, such as Canon C300 or AVCHD files from the Sony A7S.
    Would anybody have any suggestions as to why I'm unable to AMA link the XAVC clips?
    Media Composer 7.04, Windows 7 Pro 64bit, Asus Z87-Deluxe-Dual motherboard, Intel Core i7 4770K, 16GB RAM, Nvidia Quadro K4000, 256GB SSD and 2 x 2TB HDD... [view my complete system specs]
    Filed under: , ,
  • Thu, Apr 2 2015 3:36 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,850
    • Points 24,220
    Re: Unable to AMA link FS7 XAVC footage
    Possibly a sharing issue?
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Thu, Apr 2 2015 3:40 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Or to not link to the XDroot folder but rather to the folder that the Xdroot folder is situated inside of
    Tomas
  • Thu, Apr 2 2015 3:53 PM In reply to
    • DedeS
    • Posts 6
    • Points 80
    I've already tried that. Makes no difference. I'm getting the same 'Failure accessing volume information'message.
  • Thu, Apr 2 2015 3:54 PM In reply to
    • DedeS
    • Posts 6
    • Points 80
    What do you mean by sharing issue, Denny?
  • Thu, Apr 2 2015 3:55 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    and no special characters in the foldername, spacebars , or other hashes and slashes
    Tomas
  • Thu, Apr 2 2015 4:23 PM In reply to
    • DedeS
    • Posts 6
    • Points 80
    The folder name is 'Untitled'.
  • Thu, Apr 2 2015 4:38 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Ok, haven´t been on MC 7 for a long time, maybe someone with this setup will chime in with info how 4K from this cam works with MC 7
    Tomas
  • Thu, Apr 2 2015 4:51 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,850
    • Points 24,220
    What I meant by sharing, is do you have access to the drive and/or folder that the files are stored in?
    Denny
    PS complete system specs would help here.
  • Thu, Apr 2 2015 5:41 PM In reply to
    • DedeS
    • Posts 6
    • Points 80
    I have full access to the files. I've copied them with the folder structure onto my local hard drive.
    Here are my system specs: Media Composer 7.04, Windows 7 Pro 64bit, Asus Z87-Deluxe-Dual motherboard, Intel Core i7 4770K, 16GB RAM, Nvidia Quadro K4000, 256GB SSD and 2 x 2TB HDD as Raid 1, Areca Thunderbolt ARC-8050T2 with 8 x 4TB HDD as Raid 10
  • Fri, Apr 3 2015 7:53 AM In reply to
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 337
    • Points 4,245
    Can you ama to any of the individual mxf files in the clip folder?
    You need to choose xavc mxf in the ama pull down menu. Auto detect does not work.
    2x HP Z8 G4, 96GB ram, Win10 Pro 64bit, Nvidia Quadro P4000 8GB AMC 2018.12 1x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 2018.11 2x Aja... [view my complete system specs]
  • Fri, Apr 3 2015 10:33 AM In reply to
    • DedeS
    • Posts 6
    • Points 80
    AntCaladine:
    This did the trick! I chose XAVC MXF in the AMA pull down menu and instead of trying to link to the folder (as I'd do with other file types), I linked directly to the MXF files in the Clip subfolder - and voila, it worked.
    I'd found a work around using Resolve but transcoding and reframing directly in Media Composer is so much easier and quicker. Thanks so much!
