Latest post Sat, Mar 21 2015 2:32 PM by camoscato. 15 replies.
  • Tue, Mar 17 2015 9:52 PM
    • S.Clements
    • Joined on Sun, Jul 3 2011
    • London, United Kingdom
    • Posts 812
    • Points 10,755
    Supposed 25fps After Effects Quicktime reading as 20.98 fps via Avid AMA
         Just wondering if anyone might know what's going on here... I have received a quicktime file from an After Effects animator that is supposed to be 25fps, but reads as 20.91 fps in Quicktime  X and 7 and 20.98fps when linked to via AMA in Avid.  It comes into Premiere and FCP as 25fps and I can successfully import the file into Avid as 25fps Avid Media.  Does anyone know why it shows up as these odd frame rates in Quicktime and AMA?  I know it's probably more of an After Effects/Quicktime issue, but just wondering if anyone else has come across this.  The main problem I have with this situation is that I can't edit the ama-linked quicktime into the avid project and thus the film can't reliably be graded using the original file.
    Avid Media Composer 8.3.1 Macbook Pro (Retina, 15-inch, Mid 2014) 2.8 GHz Intel Core i7, 16GB Ram Mac, OS 10.10.2 [view my complete system specs]
  • Tue, Mar 17 2015 9:57 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: Supposed 25fps After Effects Quicktime reading as 20.98 fps via Avid AMA
    If QT reads it as 20.xfps, then that's what it is. The AE editor either has the project set to that framerate or their export profile is set that way.
  • Tue, Mar 17 2015 10:08 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,755
    BLKDOG:
    Thanks, BLKDOG.  I wonder why it opens in Premiere CC and FCP 7 as 25 fps with no warning of any sort.  I also thought I'd get a warning importing it as Avid Media into a 25fps Avid project, but perhaps not.
  • Tue, Mar 17 2015 10:17 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    What Codec is it? Could it be a long-GOP conversion issue?
  • Tue, Mar 17 2015 10:27 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,755
    BLKDOG:
    It says it's Apple Animation 1920x1080.  It's funny, in Quicktime 7, under "Playing FPS" (only available during playback), it says 25!  This is very strange.
  • Tue, Mar 17 2015 10:30 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,755
    Actually, the "Playing FPS" speed fluctuates wildly, but tends to snap back to 25 a fair bit.
  • Tue, Mar 17 2015 10:31 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Does it have any audio attached?  Not likely, but it can mess things up.
    You could use QTChange to alter the framerate if in fact it's a 25 fps file.
    Or you can use the console command "ignoreqtrate true" and import the QT file so it will play without trying to adjust the frame rate.  Of if you want to use AMA, see this
  • Tue, Mar 17 2015 10:33 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    I've seen that in QT before. What does QT7 say for a frame rate?
    Again, what codec is this?
  • Tue, Mar 17 2015 10:42 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,755
    hbrock:
    It does have audio attached.  After Animation codec, it says MPEG-4 HE AAC (which I've never seen on such a file before).
    I'm not familiar with QT change, but will look into it.
    I'm a bit wearing of console commands, but will look into it as well.
    Thanks for the suggestions!
  • Tue, Mar 17 2015 10:44 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,755
    BLKDOG:
    The Quicktime Frame rate is 20.91 in both Quicktime X and 7.  It's Apple Animation Codec.
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Howard is right. It sounds like the audio bit rate is what is confusing the issue. The console command is a good one for your arsenal so don't be afraid of it. AMA should also solve this.
  • Tue, Mar 17 2015 11:01 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,755
    I'm going to see if the production is fine grading the Avid MediaFiles.  If so, I think I will just import the file as Avid Media.  It seems to come in fine as 25 fps (without using the "ignoreqtrate true" console command).  When I edit it into the timeline, it has no motion adaptors on it.  If, on the other hand the colourist wants the original files, I will use the console command for ama.
  • Wed, Mar 18 2015 1:15 PM In reply to
    • cccu tech
    • Joined on Fri, Jun 17 2011
    • Posts 118
    • Points 1,350
    In QT7 the "FPS" is the part you are interested in, the "playing FPS" is what it's currently doing and will fluctuate depending on the ability of your computer to play the file back.  Try playing something back you know your system is clearly not capable of and you will see this drop and the video stutter like mad.
    Avid 5.5.3 Snow Leopard 10.6.8 2007 2x 2.8Ghx Quad Mac Pro 4GB Ram [view my complete system specs]
  • Wed, Mar 18 2015 1:33 PM In reply to
    S.Clements:
    If you use File->Import, that NEVER generates Motion Adapters, it will always bake in a frame rate conversion you cannot undo. It will list in the bin as 25fps as long as you imported into a 50i or 25p project.
    So when you write "it seems to come in fine", are you absolutely sure that there are no duplicated frames?
  • Sat, Mar 21 2015 11:13 AM In reply to
    • S.Clements
    • Posts 812
    • Points 10,755
    Job ter Burg:
    S.Clements:
        This is very good to know, Job.  I am not sure there aren't duplicated frames, so will investigate.  My ideal fix would be to get a quicktime with proper frame rate, but that is proving to be very difficult.
