Latest post Sat, Apr 28 2018 4:00 PM by GT. 7 replies.
  • Sat, Feb 21 2015 6:40 PM
    • Pixel Monkey
    • Posts 1,233
    • Points 15,560
    Geeked [8-|] Mac Editors - Do this NOW! (Disable OS Auto Updates)
    Attention all Mac-based Avid Editors everywhere:
    When you have your Mac set to automatically download and install every Apple OS upgrade that gets released, you are at fault for allowing your computer to upgrade beyond what the nice folks at Avid have tested and coded your Media Composer software to run on. (See image below for reference.)
    So do this: System Preferences / App Store / uncheck: Automatically "Install OS X Updates".
    Please and thank you. Big Smile
    For a list of which "version environments" of Media Composer & macOS and Windows are qualified by Avid, click [HERE].
    Although I would indeed advise that you download (just not install) each update that Apple releases. This way you "get" the release and can store it on your computer for WHEN Avid is able to qualify it as viable.
    Here's why:
    When Apple releases an incremental OS update like macOS 10.13.4 High Sierra, or especially a major update like a macOS "dot-zero" release, Avid's engineers get it the same day the rest of its customers do. Yes there are often times when Avid gets a BETA or "pre-release" version of the new macOS, but as you can imagine, the engineers at Apple aren't done finalizing everything. Time and time again, Avid's engineers have gotten burned by Apple because the pre-release version they obtained was drastically different than the final release. Even if one line of code was changed between pre-release and the final, it could have been a vital one that takes Avid weeks to make changes to its own code in order to accommodate. There are too many variables. For example, the OS could work fine and Composer could work fine in software-only mode, but Avid's engineers could be stuck with all their hardware drivers broken from something goofy in the OS release.
    Final Cut editors were very lucky for a long time because Apple would only release an update to FCP once they knew it was approved on the OS. That's not the case for Media Composer, Premiere, Edius or a slew of other apps.
    So on any non-Apple product (not just Media Composer), we all need to read the readme files that come with the software before installing it. The good news is that in the last 15 years, I've rarely seen a new point release of Composer released more than a month after an Apple OS release. Also you can downgrade your OS at any time. Many, many, many of us are collecting paychecks as editors while still running Lion or even Snow Leopard.
    Long story short (too late), if you have accidentally upgraded passed what your version of Composer can handle, then either downgrade your OS or wait patiently for the next version of Media Composer. It is being worked on, I promise.
    *Note: Auto Updates will only update incremental releases. For a user to upgrade to a major macOS update like High Sierra, it requires manually clicking Download and Install. So if you've upgraded to High Sierra, knowing that Media Composer is not supported on it yet, and you're seeing issues, then there's no reason to blame Avid... right?
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
  • Sat, Apr 11 2015 9:53 PM In reply to
    Re: Mac Editors - Do this NOW! (Disable OS Auto Updates)
    Hi,, I'm using protools 11.3.1 and komplete 9 ultimate of Native Instruments,, but my OS of my MAc was upgrade to OSX Yosemite ver 10.10.2.  An now I can open my sesion . What can I do, I don't have back up on my sistem ??
  • Sat, Apr 11 2015 10:13 PM In reply to
    • Pixel Monkey
    • Posts 1,233
    • Points 15,560
    Forgive me for not knowing Pro Tools. This is the video forum. I would ask the audio experts here: http://duc.avid.com
    Good luck!!!
  • Sun, Nov 15 2015 12:48 PM In reply to
    • Emer82
    • Joined on Wed, Sep 2 2015
    • Posts 2
    • Points 30
    Hello, I've installed the el capitan os and for the first two weeks, the avid media composer was working well but yestarday I installed a new el capitan upgrade and then the media composer stopped working, it's not open any more. What can I do?
  • Sun, Nov 15 2015 3:25 PM In reply to
    • Posts 10,089
    • Points 216,615
    email me your system ID.  email address is below
  • Fri, Nov 10 2017 9:57 AM In reply to
    Thanks for the info!
    Académia de idiomas con un precio imbatible y el mejor servicio. Ofrecemos los idiomas de anglès, francès i alemany.
  • Sat, Apr 28 2018 3:49 PM In reply to
    • John
    • Joined on Mon, Oct 15 2012
    • Boise, Idaho
    • Posts 189
    • Points 2,320
    Hello,
    Do you know if it's okay to update to 10.12.6.  I'm currently using MC 8.9.3
    Thank you.
    Avid MC8.9.3 iMac 27-inch, Late 2012 Processor 3.4 GHz Intel Core i7 Graphics NVIDIA GeForce GTX 680MX 2048 MB Software OS X 10.8.2 (12C2037) ... [view my complete system specs]
  • Sat, Apr 28 2018 4:00 PM In reply to
    • GT
    • South Africa
    • Posts 374
    • Points 4,095
    John:
    See here (page 17)   http://avid.force.com/pkb/servlet/fileField?retURL=%2Fpkb%2Farticles%2Fen_US%2FCompatibility%2Fen267087&entityId=ka15A000000bm91QAA&field=Attachment_1__Body__s
    MC Ver 8.7, Intel Core I5, NVidia Quadro FX 570, 16Gb Ram, 250 Gb system drive, 2 Tb Render/Media drive, Windows 7 64bit Pro, QT 7.6.6 [view my complete system specs]
