Latest post Tue, Apr 12 2016 10:46 AM by Numior. 3 replies.
  • Sat, Feb 21 2015 5:11 AM
    • ScottyD
    • New Yawk
    • Posts 89
    • Points 1,195
    Permissions Issue w/ Interplay Access / Administrator Mac 10.9.5 IP 3.1
    I've recently installed Interplay 3.1 on 10.9.5 to go along with Media Composer 8.2.2. I also installed Java for OS X 2014-001 and now I get a Fatal Error. The message reads... java.io.IOException: Permission Denied. If I open Access or Administrator as root via the terminal they open fine. If I login as root and open them they run fine. I've tried re-installing the apps to no avail. Has anyone else seen this? and if so is there a fix?
    2.66ghz Core i7 Mac Book Pro 8GB RAM 10.9.3 Media Composer 6.5.2 [view my complete system specs]
  • Mon, Feb 23 2015 3:43 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 333
    • Points 3,875
    Re: Permissions Issue w/ Interplay Access / Administrator Mac 10.9.5 IP 3.1
    Scott, did you install using root user? Tried java rollback via pacifist yet?
    Dave
    "A very big network"
  • Mon, Mar 9 2015 7:37 PM In reply to
    • bowenc
    • Joined on Wed, Jul 25 2012
    • Posts 2
    • Points 20
    Have you had any luck with a solution? I have the same issue, 10.9.5, Interplay 3.1 and MC 8.1 while trying to test build a clean lab image. It's a clean 10.9.5 install, fully updated and the only 3rd party software is ISIS client, Interplay and MC. I did not install as root just an admin user.
  • Tue, Apr 12 2016 10:46 AM In reply to
    • Numior
    • Joined on Thu, Dec 6 2007
    • Saint-Petersburg, Russia.
    • Posts 12
    • Points 100
    Had this with a customer on Mac OS v10.10.5 with IP v3.4
    Running to show files access failures:
    $sudo opensnoop -n AvidInterplayAccess -x
    Comparing with other user having no problems starting up Access.
    Ended up changing permissions to these files:
    $sudo chown [username] /Users/[username]/Library/Workgroup
    $sudo chown [username] /Users/[username]/Library/Preferences/Workgroup/media_access.settings
    $sudo chown [username] /Users/[username]/Library/Logs/Workgroup/workgroup.log
    Where [username] should be substituted with the user, having below error message, i.e. $sudo chown admin /Users/admin/Library/Workgroup
    All those files/folder had root user set as their owner, somehow.
    Hope this helps!
