Latest post Fri, Feb 27 2015 3:00 AM by BobbyMurcerFan. 7 replies.
  • Fri, Feb 6 2015 6:37 PM
    Avid just will not work for me
    I downlaoded Media Composer 8.3 and it works fine on my husbands computer but not on mine. It starts fine and I see my bins and what not but the Composer window is frozen. I can click any footage and it'll play the sound but not the video (even if you put it on the time line. Something else I noticed is that if I move a window over the composer window then it drag lags and leaves a repeated picture of the window being dragged all over the composer window.
    My specs are:
    Geforce GTX 770M
    Quad Core i7-4700MQ 2.4GHZ
    16GB RAM
    It's a toshiba qosmio laptop. It runs all of adobe CC perfectly but Avid just won't work no matter what I do.
    Suggestions?
    TOSHIBA QOSMIO X75-A7180 256GD SSD + 1tb HDD NVIDIA GeForce GTX 770M (3gb dedicated) Quad Core I7-4700MQ 2.40GHZ 16GB RAM Windows 8.1 [view my complete system specs]
  • Fri, Feb 6 2015 7:05 PM In reply to
    • Pixel Monkey
    • Posts 1,231
    • Points 15,520
    Re: Avid just will not work for me
    First step would be to check the readme (here) to verify that your computer and its version environment is qualified to run MC8.3.  Check the exact version of the OS you are running, check the version of Quicktime, the video card driver, etc... If you find everything is in order, then report back and we'll be happy to troubleshoot further.
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
  • Fri, Feb 6 2015 9:32 PM In reply to
    My Quicktime is up to date according to that link, my video driver is beyond up to date according to that link, I am running windows 8.1
    Everything seems fine on my side.
    Video not playing in the composer window, but it will play the audio and the buttons are still usable, I can still make subclips and marker and in and out points I just can't see anything.
  • Fri, Feb 6 2015 10:17 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,343
    • Points 16,510
    Aileen Michelle:
    The symptoms you're describing could be caused by this.  Something is interfering with the screen redrawing.  Try rolling back to the Avid-approved driver even though your video card is not a quadro.  Keep a copy of your current driver to reinstall if it doesn't make any difference.
  • Fri, Feb 6 2015 10:36 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,321
    • Points 53,415
    Some i7 Chips also carry onboard GPU functions. You'd want to make sure on-chip video is turned off in BIOS.
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Thu, Feb 26 2015 11:19 PM In reply to
    I tried rolling back and my graphics went crazy. Tried Avid and it still didnt work :/
  • Fri, Feb 27 2015 2:41 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,321
    • Points 53,415
    Which nVidia driver are you using? Usually the GeForce driver should come close to the Quadro version
    If the Quadro Driver is 340.84,
    GeForce Version: 340.52 would be a good place to start.
    The Quadro drivers rarely lineup at the point level with the Geforce ones.
  • Fri, Feb 27 2015 3:00 AM In reply to
    FIW, I find that the 344.75 GeForce driver works really well with my GTX 970.
