Latest post Tue, Sep 4 2018 9:12 PM by Boky. 4 replies.
  • Thu, Feb 5 2015 8:28 PM
    • rupertvdb
    • Joined on Thu, Feb 5 2015
    • Posts 18
    • Points 230
    Setting clip names for Autosync
    Hi all,
    I'm on set doing some syncing and I am looking at the soundie's track names, which are amazing, have scene numbers, slate and take information, all clear and concise, and I'm dying inside because I know once I autosync this with the footage from the pair of Sony F5s we are using this name will be replaced with the generic A001etc of the video clips.
    Is there any way to specifiy that you want to use the Audio track names for the title of the autosynced subclips rather than the video tracks?
  • Thu, Feb 5 2015 11:06 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,353
    • Points 16,640
    Re: Setting clip names for Autosync
    When you select your clips in the bin to auto sync, avid will use the name of whichever clip is on top.  Arrange your clips so the audio is higher in the bin than the video.
  • Fri, Feb 6 2015 7:43 AM In reply to
    1. Create a custom called “Name2” or whatever you choose.
    2. With bin containing only the BWF clips, highlight the “Name” column and duplicate (cmd-D or ctrl-D) it to the previously made custom column (“Name2”)
    3. AutoSync the clips as per usual
    4. Move .sync clips to their own bin.
    5. Highlight “Name2” column and highlight as described in Step 1 and duplicate it back into the Name column.
    6. All .sync clips now have the name from the BWF parsing
  • Fri, Feb 6 2015 5:15 PM In reply to
    • rupertvdb
    • Posts 18
    • Points 230
    Thanks, that's a logical way around the issue but a bit long winded. I was hoping there was a quick way, i'll try the approach mentioned above but if that fails at least this way works. Thanks!
  • Tue, Sep 4 2018 9:12 PM In reply to
    • Boky
    • Joined on Fri, Apr 21 2006
    • Posts 29
    • Points 385
    This is what I was looking for. It will save me a lot of time! Thank you!!!
    SYS1: MC 8.3.1, Supermicro X7DWA, 2X Intel Xeon X5460(quadcore) @3.16GHz, Nvida Quadra 2200, 16GB ram SYS2: MC 8.4.0, Asus P5K-E, Q9550 @3.5GHz, Geforce... [view my complete system specs]
