Hi All,
I just upgraded to Media Composer 8.3.0 I am currently running an HP Z800 with 12GB of memory (6 - 2GB DDR3 133 ECC memory cards). What options do I have for upgrading memory to 32GB that Avid will access. I can only find info on the Z800 going to 12GB. Can I populate the rest of the slots with 6 more 2GB DDR3s? Do I remove that memory and add 6 - 8GB mem cards? I can't find any info on this in the forum or from Avid. There is info on later HP machines but not the Z800. I believe it's likely some of you are running a Z800 with Avid 8.3.0 and more than 12GB? If I can increase memory what slots do I use? Thanks for any help.
Arnie
arnieitz@optonline.net
We followed the HP advice on adding RAM to ensure optimum system performance. Avid seems to work fine with that.
I think we have a 24GB Z800 running V8.3 fine.
Hi Pat,
Would you be able to tell me what size mem chips you are using and in what slots they are in.
Hi Again,
I got a reply from Avid that says more memory is useful but did not answer my question. In the Avid Z800 configuration guidlines is only addresses 12GB. I currently have 2GB DIMMs in slots DIMM1, 2 & 3 for both CPU0 & CPU1 as Avid recommends. What slotts can I use with version 8.3.0 on the Z800 to go to more memory and what size DIMMs. Can I populate the other 6 slots with the same 2GB DIMMs I am currently using to get 24GB?. Should I pull all those DIMMs and put in 6 - 8GB DIMMs in the same 6 slots? Will that work and will Avid access the memory?
I have a Z800 with 48GB of ram, adn MC 8.3 run ssmoothly as can be.
As Pat mentioned if you follow the HP guidelines with a nod back to the Avid specs you can see what's best.
Check the HP site for config options and guidleines.
Thanks. Memory is on order. Pulling 2GB DIMMs & putting in 12 - 4GB DIMMs.
