Latest post Tue, Mar 12 2019 2:16 PM by Tilmann. 17 replies.
  • Wed, Dec 24 2014 10:16 PM
    • sven2615
    • Joined on Wed, Apr 12 2006
    • Berlin
    • Posts 152
    • Points 2,030
    Group Video and Audio Clips in Timeline
    Assume you edited a really fast action sequence and did some awesome sounddesign within the limited few audio tracks.
    There are some hits, crashes and impacts you want to stick to a certain video clip forever. So you may want to merge/group these clips. Similar to the "group clips“ feature to sync video and audio subclips, but not in bins, in the timeline.
    The feature could also work like a more eloborated sync lock feature (only locks the whole track). You could also have some clips or maybe a whole scene wich is already perfectly done in picture and sound and you want to make sure that it doesn’t change in your 100 minute sequence. You would simply span a lasso or select all clips you want and click „group“. The grouped clips would be same colored like it looks when clips are muted e.g.
    When you wanna move the grouped scene you would simply need to click once, it would behave like one single clip.
    Avid Media Composer 7.0.3 | MacPro 3.5 GHz 6core 32GB RAM | AJA T-Tap |||| The Audio Mixer is too BIG since mc6!!! [view my complete system specs]
    www.svenbudelmann.com
    http://www.imdb.com/name/nm0118967/
  • Fri, Dec 26 2014 10:17 AM In reply to
    Re: Group Video and Audio Clips in Timeline
    +1 (it does exist on Adobe Premiere, btw)
    Avid Mediacomposer 6.5.0 Mac/PC with Nitris [view my complete system specs]
  • Fri, Dec 26 2014 12:00 PM In reply to
    Hi guys, this already exists in MC.
    You can save a whole sequence as new clip, you just need to drag the clip icon in the monitor, and drag it to a bin with the ALT key. Try it, and see if it is what you were looking for.
    Best.
          Diego
    * Avid Media Composer 2018.2 * Interplay | Production 3.8.1 * Media Central 2.10
  • Fri, Dec 26 2014 12:55 PM In reply to
    • sven2615
    • Berlin
    • Posts 152
    • Points 2,030
    diegovillalba:
    Hi Diego,
    unfortunately it doesn't exist. What you are describing only makes a copy of a section of the sequence which "itself" still behaves like a sequence. Because it is a sequence.
    I want that bit of a sequence to be a CLIP, made of video and audio clips that I selected before in a sequence.  There is a similar feature that only works with video. It's called collapse, but it's not that handy especially when you want to de-collapse. and it doesn't work with video and audio together.
    I'm talking about a "collapse-video-and-audio-clips-together" feature.
    I'll check adobe premiere.
    best
    sven
  • Fri, Dec 26 2014 1:20 PM In reply to
    • switthaus
    • Cobbs Creek, VA
    • Posts 2,254
    • Points 30,475
    Check FCPX as well.  It's called a Compound Clip and they are very handy for many reasons.
    *Edit* - Here is an overview: http://support.apple.com/kb/PH12630
    Scott Witthaus
    Owner/Editor/Post Production Supervisor 1708 Editorial
    http://vimeopro.com/1708editorial/1708-editorial
  • Fri, Dec 26 2014 1:34 PM In reply to
    +1.
  • Fri, Dec 26 2014 3:03 PM In reply to
    Yeah, this is a Premiere Pro and FCPX thing.  I wish we had "grouping" like this for Media Composer.
    Home: 2012 rMBP 2.6ghz, 16GB RAM, OSX 10.10.5, MC 8.4.1 || Work: HP Z400, Win7 Professional, MC 6.5, ISIS/Interplay @danielfrome on twitter [view my complete system specs]
    Avid GoPro
  • Sat, Dec 27 2014 2:56 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,386
    • Points 97,010
    As far as video is concerned you do, but there isn't a similar thing for audio, nor can you tie the audio to the video.  If you're interested in the video-only equivalent, mark you region and click the submaster icon.
  • Sat, Dec 27 2014 2:24 PM In reply to
    • switthaus
    • Cobbs Creek, VA
    • Posts 2,254
    • Points 30,475
    That's the cool thing about Compund Clips.  You can throw anything in there and always be able to hop in and change whenever, as it will open up on it's own project timeline.  You can easily break it apart again to it's separate items at any point.
    The Compound Clip also becomes a regular media clip in the browser, so if you built a graphic animation that was to be used over multiple openings, for example, create it once and then make a Compound Clip from it.  It becomes a single clip in your Library, but can always be opened and tweaked to fit whatever you are putting it over.  Plus you can add  CC, effects, sound, whatever you can do to a regular media clip.
    Powerful voodoo.
    Scott Witthaus
  • Sat, Dec 27 2014 2:38 PM In reply to
    • sven2615
    • Berlin
    • Posts 152
    • Points 2,030
    switthaus:
    You can throw anything in there and always be able to hop in and change whenever,...easily break it apart again to it's separate items at any point... Compound Clip also becomes a regular media clip in the browser...
    Thats exactly IT!!!! thanks switthaus.
    better do a perfect copy of something existing than inventing someting new with all its childhood illnesses ;)
  • Sat, Dec 27 2014 6:40 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,365
    • Points 16,830
    sven2615:
    I know a number of patent attornies and responsible CEOs who may disagree with you. Wink
    Actually. much of the compound clip capability already exists with a creative combination of collapsing, subclipping and autosynching.
    The bigger problem (for me) occurs in not being able to use edited subclips and subsequences as multicam sources.
  • Sun, Dec 28 2014 11:53 AM In reply to
    • switthaus
    • Cobbs Creek, VA
    • Posts 2,254
    • Points 30,475
    smrpix:
    Indeed.  If you look at Resolve and FCPX, they are amazingly close in interface design and functions.  I am sure the Resolve attorneys took good long looks into the product before releasing it!
    smrpix:
    The thing Avid needs to do is make this one-click and give at least some of the options noted above.
    Scott Witthaus
  • Tue, Dec 30 2014 12:36 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 572
    • Points 6,450
    • Moderator: Avid DS
      Moderator: MetaFuze
    There's something similar in their defunct DS software that they already have patents for. I don't think that's what's stopping them.
    switthaus:
    smrpix:
    smrpix:
    "There are no rules for the brave". Albert Einstein
  • Wed, Dec 31 2014 12:39 PM In reply to
    • switthaus
    • Cobbs Creek, VA
    • Posts 2,254
    • Points 30,475
    There are a lot of good things in DS that Avid continues to ignore.
    Scott Witthaus
  • Wed, Dec 31 2014 12:44 PM In reply to
    DS? What's DS?
