Latest post Mon, Aug 11 2014 1:16 PM by smrpix. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Aug 11 2014 12:52 PM
    • Davio
    • Joined on Mon, Aug 11 2014
    • Posts 5
    • Points 85
    Edit a multigroup clip
    Im working with a big project that have some moments that have 14 videostreams that I need to group together into a multigroup. This project is then sent to the editors to be worked on.
    Now discovered bit late when the editors have begun their work that another audio stream needed to be insert into the multigroup, and I have tried to find a way to insert a new stream inside an already existing multigroup clip to save everyones time so they dont need to redo everything.
    Is there a way to edit an already existing multigroup to include another stream instead of redoing everything?
    We are currently using Avid Media Composer 8.0
  • Mon, Aug 11 2014 1:16 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,373
    • Points 16,950
    Re: Edit a multigroup clip
    No.  Hopefully you've saved your sync map sequence with the add-edits so you don't have to start completely from scratch.
    This is a longstanding feature request.
