Latest post Mon, Aug 4 2014 5:44 PM by smrpix. 2 replies.
  • Mon, Aug 4 2014 3:16 PM
    AVID loses footage links *Media ongoing Offline*
    Hi everyone,
    I have a problem using AVID Media Composer 8:
    My project is finally cut. I linked all media with AMA but AVID loses these AMA links suddenly while I'm working on the project. So I relinked all AMA files several times but the links break again and again.
    Now I transcoded each AMA file to MXF (DNxHD 185) and then relinked it with "Clip -> Relink" to the new MXF files in AVID Media Files but the media goes offline further on. Was this method of exchanging AMA with MXF-files right?
    I don't know how to restore my project. I already deleted all database-files in AVID Media Files directory. No change. There were no changes on my HDD, where footage and project files exist.
    Could it also be a solution to create a new project, import only all MXF files and use an EDL?
    Thanks a lot for your help!
    Best regards, Niko
    Filed under: , , ,
  • Mon, Aug 4 2014 5:27 PM In reply to
    Re: AVID loses footage links *Media ongoing Offline*
    When you transcoded to DNX185 you should have got a bunch of .new master clips.
    A copy of your working sequence shoudl easly have been relinked to the DNX185 media. From that point on you shouldn't be using AMA media at all.
    The clip re-link should ahve been done on the sequence and not the AMA masterclips (depsite this being a widely and unhelpfully described workflow on the web)
  • Mon, Aug 4 2014 5:44 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,354
    • Points 16,655
    It might be worth checking if the system or external drives aren't on some energy savings settings that might be putting them to sleep after a time.
