Latest post Sat, Jul 26 2014 7:30 PM by swhiteindiana. 1 replies.
Page 1 of 1 (2 items)
  • Sat, Jul 26 2014 6:06 PM
    • swhiteindiana
    • Greenville, SC
    • Posts 41
    • Points 505
    AMA linking problem
    I have recorded with two Panasonic caameras.  Either one of the cameras or some of the P2 cards seem to have a problem.  I've uploaded the video from the cards to a hard drive, and all of the MXF files are there and when I AMA link to the folders that hold them, Not all of the subdirectories have a problem.  I get the message on the console that the link is good, but there is no AMA clip in the bin.  Here's the message from the console:
    Link To AMA Volume -> F:\FTL 8 B-2\
    MVP Used:[ Plugin Name = PanasonicP2 MVP_MSP Plug-In Panasonic. Version = 4.2 ]
    MSP Used:[ Plugin Name = PanasonicP2 MVP_MSP Plug-In Panasonic. Version = 4.2 ]
    AMA link to volume F:\FTL 8 B-1 was successful.
    AMA link to volume F:\FTL 8 B-2 was successful.
    Does anyone have this experience.
    Is there any other way to get the P2 media???
    Media Composer v2018.8 using: HP Z400 Workstation Intel Xeon w3550,3.07GHz; 16GB RAM Windows 10 NVidia Quadro 2000; Driver:392.0 [view my complete system specs]
    Filed under: , , , ,
  • Sat, Jul 26 2014 7:30 PM In reply to
    • swhiteindiana
    • Greenville, SC
    • Posts 41
    • Points 505
    Re: AMA linking problem
    I'm not sure at all what is the cause, but I am selecting a P2 plugin that refers to (*.MXF) meaning that it's pointing to files and linking to the files in the Video and Audio folders separately inside the card subdirectory and getting results...  You have to two links to get the audio and video.
    Sometimes it just requires a bit of experimenting to find the answer.... I don't know if this is a new thing or not, but it's saved me from certain ruin. If you use the folder it will indicate success, but not show you a clip in the bin.  Whereas some of the P2 cards I saved would link to the files, these troubled ones are showing up using the P2 (*.MXF) plugin.
