Latest post Wed, Jul 23 2014 5:37 AM by newyankee. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Jul 21 2014 10:00 AM
    • Peter Lund
    • Joined on Mon, Sep 22 2008
    • Hamburg
    • Posts 146
    • Points 1,755
    extra keyboard for shortcuts ?
    apart of the euphonix interfaces is there any extra keyboard we can use
    to map shortcuts or key´s to?
    thanxs
    pele2010
    ___________________________________________________________________________________________________________________ Avid MC 7.0.4 /// MacBooks pro early... [view my complete system specs]
  • Mon, Jul 21 2014 6:49 PM In reply to
    • DFW Hokie
    • Plano, TX
    • Posts 272
    • Points 3,670
    Re: extra keyboard for shortcuts ?
    Contour Design makes two products that may be the type of thing you are seeking:
    ShuttlePRO v2
    ShuttleXpress
  • Mon, Jul 21 2014 7:19 PM In reply to
    DFW Hokie:
    ShuttlePRO v2
    Does it still work with MC?  I have not had either of my mine here (on PC's)  work since MC 6
  • Mon, Jul 21 2014 7:40 PM In reply to
    • DFW Hokie
    • Plano, TX
    • Posts 272
    • Points 3,670
    AndrewAction:
    DFW Hokie:
    ShuttlePRO v2
    Three answers:
    1.  Did you download the Media Composer 7 settings from the Contour Design website?
    2.  I can't imagine why the Contour Design Shuttle would not work with a newer version of Media Composer.  It's essentially just a keyboard substitute (even the jog/shuttle wheel).  You might have to manually "point" at the Media Composer *.exe file, however, to get the settings to load up with the Media Composer launch.  (Downloading the settings I mention above should take care of all this, but even without a settings file from the factory, a custom settings profile can be created for any program that uses keyboard shortcuts.)
    3.  I'm still on Media Composer v6.
  • Mon, Jul 21 2014 8:11 PM In reply to
    Thanks, The Shuttle Pros did not work for me with MC 6 or 6.5 so I moved to Artist Color. Only really get 9 keys (and 9 Shift keys) to program there per menu.
  • Mon, Jul 21 2014 10:45 PM In reply to
    • Saylur
    • Laguna Woods CA
    • Posts 485
    • Points 6,120
    I made a custom  setting profile on my Shuttle Pro and it works fine on MC 6.05.
    MC-6.0.5,MB Asus Z87 Expert 1150 ATX,Intel Core i7 4770 3.4 Ghz CPU,32GB Kingston DDR3 Mem.,Samsung 840 250GB SSD,Win 7 Pro SP 1, QT 7.7.3,PNY Quadro K2000... [view my complete system specs]
    Regards
    Mike
  • Tue, Jul 22 2014 7:40 AM In reply to
    • newyankee
    • Joined on Sun, Sep 16 2007
    • Palo Alto, Ca
    • Posts 216
    • Points 2,785
    I use a Corsair K90 "gaming" keyboard with 18 dedicated shortcut keys.
    http://www.engadget.com/products/corsair/vengeance/k90/
    typically I map functions to the "ALT" layer keybaord in Avid, and then map the ALT combinations to the K90 keys.
    Asus P9x79Pro MB, Intel I7 3930K overclocked to 4GHz, Quadro FX3800, MC 8.3.1 /Symphony, Raid 0 / 3ware controller, Win 7 Pro 64, 32 Gig Ram, Matrox MX02... [view my complete system specs]
  • Tue, Jul 22 2014 10:12 AM In reply to
    • Peter Lund
    • Hamburg
    • Posts 146
    • Points 1,755
    Hi ,
    how can you map to the "alt" keyboard (option) .
    i only can map to shift and normal ?
    thanxs ....
    good tip with the K90 :-)
  • Wed, Jul 23 2014 5:37 AM In reply to
    • newyankee
    • Palo Alto, Ca
    • Posts 216
    • Points 2,785
    Peter Lund:
    you are right...ment shift.  Was working from flakey memory.
