Latest post Sun, May 25 2014 6:44 PM by lunalobo75. 5 replies.
Page 1 of 1 (6 items)
  • Fri, May 23 2014 1:33 PM
    • EasyL3
    • Joined on Thu, Oct 25 2012
    • Posts 8
    • Points 130
    Transfer from Avid MC to Premiere CC
    Hey all, just want to check in to see if there's an easier workflow for what I'm doing.
    I have a 45  minute piece on my MC that I need to transfer to Premiere CC. I thought I'd have to consolidate the sequence and export all clips as QT's,  but I'm reading that it might be possible to simply select the sequence and export as AAF and Premiere will be able to read the sequence and all native footage?
    This would save me hours/days if true. Can anyone confirm this for me?
    Much appreciated!
  • Fri, May 23 2014 2:56 PM In reply to
    Re: Transfer from Avid MC to Premiere CC
    Hi.
    Hope helps:
    https://www.youtube.com/watch?v=UdoMqrp51Gs
    CV
    AVID MEDIA COMPOSER 5.5.3. PC. WINDOWS 7, SP1. 64BIT OPERATING SYSTEM. QUICK TIME VERSION 7.6.9. [view my complete system specs]
    Christian Jhonson
    Avid Ambassador
    christianjhonsoon@hotmail.com
  • Fri, May 23 2014 4:24 PM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Yes. Export AAF. This what I do amd it works beatifully.
    HP Z800 MC 8.3, Adobe CC, Windows 7 Ultimate 64-bit SP1, 2 Hex Core X5650 @ 2.67GHz, 48Gigs Ram, NVidia Quadro K4000, Sandisk Extreme 240 gig SSD System... [view my complete system specs]
  • Sun, May 25 2014 6:06 AM In reply to
    • sasha1
    • Posts 394
    • Points 5,265
    the video says you can only do it with AMA'd files, but not with avid mxf files. is there any way to accomplish that, maybe by consolidating (and losing links to original files)?
    Avid 1: HP Z420. Quadro 4000, Motu, MC 7.02. Avid 2: Dell T3400 - Core 2 Quad 2.83 - 8GB RAM - Quadro K2000 - Matrox Mini - MC 7.02 [view my complete system specs]
  • Sun, May 25 2014 4:24 PM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 155
    • Points 1,900
    You are wrong. It's works with MXF files.
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Sun, May 25 2014 6:44 PM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    gorky is right: it's the way to get your mxf's tp premiere. Go ahead and try it; but; just remember, it may not bring over some transitions ot effcts you have laid out in avid.  A straight edit with some easy transitions will work.
