I have a bunch of BetaSP and DV footage that I digitized from a deck.
I want to use this in a HD project.
I am trying to use BBC Uprez.
It seems to only work on imported clips.
Is there a way to use it on digitzed footage or am I going to have to export and reimport all?
Thanks.
Capture in SD, export Same As Source / 601 / non-square in SD. Import the result in HD with the box "do not resize smaller images". You will now have a PIP where a pixel has stayed a pixel. Apply UpRez, set the source to SD NTSC or SD PAL (as applicable), set the destination size to HD 1920x1080, and choose the appropriate scaling method.
So there is no way to do it on the original source fotage.
I have LOTS O Clips.
I know of no other way. If this is a bunch of clips, you could of course only do this for sections of the final cut.
