Latest post Sun, Jan 18 2015 1:33 PM by mjolnarn. 3 replies.
  • Fri, Feb 28 2014 4:25 PM
    Wrong format when linking with AMA
    I've filmed a number of events using a Sony HXR NX5E camera that uses AVCHD. I've shot it all at 1080p 25.
    I've set my project up so that its 1080p/25. When I've linked to the AVCHD files using AMA they show up in my bin as Fromat HD 1080i/50 and Video H.264 (1080i 50). When I imported a small file to test if it was my settings or the original files they imported at the correct format of HD 1080p/25 and Video DNxHD 120 (HD1080p).
    I don't know why this is happening and any suggestions why would be greatly appreciated.
    I'm using Avid Media Composer 7.03 Interplay Edition on a imac 3.4 GHz Intel Core i5 using OSX10.9
    Filed under: , , , ,
  • Fri, Feb 28 2014 5:00 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: Wrong format when linking with AMA
    It´s a ( reported ) bug , just add " field motion " to your bin header and switch to progressive, you can do that to all clips at the same time.
    The command " refresh sequense " will remove possible automated applied motion adapters.
    Tomas
  • Sat, Jan 17 2015 7:02 PM In reply to
    • Jlorenzen
    • Joined on Mon, Jul 4 2011
    • Posts 25
    • Points 310
    I just have same issue but field motion shows the clips are progressive
    I'm ready to quite day one, why do people shoot sizzle reels if they can't tell me the right info about their own project!
    FML
    Avid 8.0 OS Yosemite 10.10 iMac 5k 16gb Ram [view my complete system specs]
  • Sun, Jan 18 2015 1:33 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Jlorenzen:
    A couple of things to check here, start with analyzing the origin media , Mediainfo , do a google, might be a way.
    If the file info in the bin differs from what Mediainfo says, you can also check for yourself what type the media is by, in an interlaced project and ama linked media, step from field to field, you might want to assign a button for this , I have replaced the defaults commands at 3 and 4 with stepping fields instead of stepping frames myself, please follow the above advice to change the properties.
    Tomas
