Latest post Mon, Feb 3 2014 8:06 AM by Marianna. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Jan 27 2014 9:41 AM
    • dowbyc
    • Joined on Sat, May 4 2013
    • Posts 5
    • Points 75
    Text "Wave" Effect
    I'm fairly new to AVID, and I'm currently working on a video that has a lot of ocean shots in it.
    I would like to figure out how I can make the Title Text move onto the screen as though it's floating in on a close up shot of some waves on the beach that I have.
    I'm assuming that I'll have to warp the lettering somehow, but I'm not sure what the best way to do that in AVID would be, or what effect may be best.
    Any ideas?
  • Mon, Jan 27 2014 2:20 PM In reply to
    Re: Text "Wave" Effect
    You should be able to promote the title effect to 3d, and then under the Shape parameter select Ball.  You'll have to play around with it and keyframe it to get it to look like a wave, which will probably be a pain, but there's no built-in "wave" effect that I'm aware of.
    I'm sure other people will chime in with ideas, and hopefully one of them will be better than mine.
    Media Composer 2018.12.2 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Mon, Jan 27 2014 3:04 PM In reply to
    • Posts 10,204
    • Points 218,070
    dowbyc:
    Hello Dowbyc,
    I have no idea what version of Avid you have.
    (In fact you may even be using Avid Studio - which is no longer an Avid product, and should be looked for at http://forums.pinnaclesys.com/forums/242/ShowForum.aspx )
    But let's say you have Avid Media Composer version 6 or higher..... then you have AvidFX as well.
    Here is a short tutorial on how you can easily achieve the wave effect you are looking for  http://www.screencast.com/t/tBZxKgUvM
    You will have to fine tune the parameters. But it is possible that it will work as I show - straight out of the box.
    Good luck
    Douglas
  • Mon, Feb 3 2014 8:00 AM In reply to
    • dowbyc
    • Posts 5
    • Points 75
    Thank you so much for taking the time for that video!
    Currently I am working with AVID 5.5, so I don't beleive I have the same version of the effect editor, but it was very interesting to watch!
  • Mon, Feb 3 2014 8:01 AM In reply to
    • dowbyc
    • Posts 5
    • Points 75
    Thank You for the Reply!!
    It sounds similar to what I was thinking, I just didn't quite know how to start. So Thank You! I'll give it a shot and play around, I'm excited to see if I can make something work.
  • Mon, Feb 3 2014 8:06 AM In reply to
    • Posts 10,204
    • Points 218,070
    dowbyc:
    Yes , Good luck!
    Regards
    Douglas
