Latest post Mon, Jan 27 2014 9:46 PM by BenoitM. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Jan 24 2014 1:06 PM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    Replace audio clip and keep volume automation
    Sorry if it is a RTFM thing...
    I don't remember how to replace an audio clip with another of the same duration (and bitrate etc.), while keeping the volume automation (and keyframes) already present on the track.
    MC 2018.12 (Symphony option)/BCC 10.0.5/RED 5.6; BlackMagic Ultrastudio Mini Monitor (10.11.2.0); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz - 32... [view my complete system specs]
  • Fri, Jan 24 2014 1:33 PM In reply to
    Re: Replace audio clip and keep volume automation
    Don't apologize, I think that's more of a WTFM thing. But IF it does exist and is written in the manual, please share the location.
  • Fri, Jan 24 2014 2:24 PM In reply to
    • fkurz
    • Joined on Wed, Jan 23 2008
    • Posts 31
    • Points 380
    Hi!
    Since MC or SYM 6.5 you are able to copy and paste audio keyframes. So you can cut the new audio clip in your sequence, select and copy all the keyframes from the clip you want to replace, paste them to the new clip and delete the old clip.
    Maybe that could be the thing you're looking for.
    Regards
    Flo
    Avid MC 2018.2 symphony option HP Z820 Win 7 64Bit, SP 1 Mojo-DX Interface [view my complete system specs]
  • Fri, Jan 24 2014 2:35 PM In reply to
    Just take care that the new pasted keyframes will start at the playhead so either mark an in at the first keyframe point or easier add a keyframe at the very start of the clip. Then the subsequent copy and paste will drop them back in the same position (otherwise typically your keyrames all get shifted left)
    There isn't a right click copy or paste just use the ctrol-C ctrl-V
  • Fri, Jan 24 2014 6:35 PM In reply to
    If the clips are the same duration, you could Batch Import and it'll replace the media, leaving your timeline adjustments in tact.
  • Mon, Jan 27 2014 9:46 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    I thought there was a more straightforward way to accomplish this....thanks for all the useful suggestions
