Latest post Mon, Aug 11 2014 6:02 PM by Pat Horridge. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Jan 21 2014 7:55 PM
    • dnext
    • Joined on Wed, May 6 2009
    • Posts 27
    • Points 360
    AMA linked clips turning into offline master clips
    Using MC 7.0.3, OSX 10.8.5 on a MacPro.
    After we close and reopen a project, we discover random clips changed from AMA linked to offline master files.
    The linked clips will work fine as we edit, we'll close the project, return to it the next day and certain AMA files will now be offline with the master icon in place of the original AMA link icon.
    We've tried relinking in the suggested ways but with no success and a lot of frustration.
  • Tue, Jan 21 2014 9:00 PM In reply to
    Re: AMA linked clips turning into offline master clips
    What kind of footage are you linking and from what kind of storage? I once had this happen with Pix240 footage that was shot as DNxHD. http://community.avid.com/forums/t/114135.aspx
    btw, an offline AMA clip will not have a normal AMA icon because it only shows it that way (linked icon) when it is actually linked to something. So it makes perfect sense that it would look like a normal Master Clip icon.
  • Tue, Jan 21 2014 9:33 PM In reply to
    • dnext
    • Posts 27
    • Points 360
    Thanks for the reply and insight on the icons.
    Clips are all DNxHD.
    Some recorded on a Samurai Blade at DNxHD145
    Others 5DM3 movs transcoded via MPEG streamclip to DNxHD145.
    Haven't had any problem with AMA in the past.
    Only with the upgrade to 7.0.3
  • Tue, Aug 5 2014 3:26 AM In reply to
    • John Durst
    • 48 W. 76th St, NY NY
    • Posts 57
    • Points 670
    I have exactly the same problem.  What's happening, do you know?
    HP Elitebook 8760w Dreamcolor i7 QC 2.3 ghz 17 32 gb 750 GB Quadro 4000. Many external multiGB drives. Windows 7 Pro, MC 6.5.4 Pro Tools 12. [view my complete system specs]
  • Wed, Aug 6 2014 1:13 AM In reply to
    JUST experienced this frustrating phenomenon today, whilst opening a project containing AMA-linked material. AMA clips had magically transformed into offline clips.  Really flummoxed me, as the icon showed as a standard clip - tried 'get info' but no use, as it couldn't see the original file on the network.
    Made me crazy.  I re-imported for reals and threw it in that way.
    To quote Kevin K from long ago... "AMA is the devil"
     LOVE AMA, but this is not good.
    2 systems: Mobile: 15-inch Macbook Pro Retina 2.6GHZ i7 w/16 gig RAM, 1TB SSD, OS 10.14.4 running MC 2018.12.3 Legacy - MC v5.5.4, OS 10.5.8, QT 7.6, on... [view my complete system specs]
  • Wed, Aug 6 2014 4:05 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    Try right clicking on the file and choosing "relink to AMA"
    Relink problems normally occur because of 1 of 2 things:
    1. The original media has been moved or deleted and AMA can't find it
    2. The version of an AMA plug in has changed and it can no longer interpret the media correctly (don't get me started on what I think of this!)
    For volume based AMA (Eg XDCam / P2 / AVCHD cams) then relinking to the volume usually brings all the clips back on line. For individually linked clips then...
    For 1. usually my solution at the top of the post will work
    For 2. you are better off reverting to the old version of Avid and the plug in, making sure the media is in the same place and consolidating/transcoding before upgrading. Nothing much seems to work.
    John
  • Wed, Aug 6 2014 6:28 AM In reply to
    Bill Nelson:
    Don't import. Re AMA link and Transcode.
    AMA linked content is great but it's still not as robust as Avid Media so if you need to AMA link and transcode.
  • Mon, Aug 11 2014 4:21 PM In reply to
    would LOVE to relink somehow. There's the rub. The AMA link dialog is greyed out for that clip.  I had to import the clips again
  • Mon, Aug 11 2014 5:05 PM In reply to
    • dnext
    • Posts 27
    • Points 360
    This may not be applicable in these or most cases but here's one thing we discovered regarding this in one particular situation.
    We had a project where we had been AMA linking hundreds of clips from a multi-camera shoot using multiple Canon 5DM3s. The problem (and we are kicking ourselves on why we didn't notice this going in) was that some of the file numbers from different cameras overlapped. A file from Cam A on day 1 might be MVI_1923.mov and two days later an AMA link for a file from Cam C would have the same number. The scenes would AMA link fine at first. But with a reboot, the system somehow got confused about which clip was which and went offline.
    Again, we still had the problem we described at the top of this thread on some other clips. But also noticed (and fixed by renaming) this issue on others.
  • Mon, Aug 11 2014 6:02 PM In reply to
    Non robust AMA formats, like5D and others, that have no UMIDs (64 byte unique id numbers) need to managed with care. Lots of posthouses pre re-name all their files to avoid this. Or AMA link and make finishing media and then make offline media from that and never go back to the camera sources.
    multiple 5D clips with overlapping file names is a tapeless workflow 101 lesson.
    On the re-linking yes the re-link option often isn't there but you can normally mass AMA link down through multiple folder levels into a dummy bin and bring whole batches of AMA clips back online. Re-AMA linking isn't making more media and is very fast.
    It's not ideal but it is manageable.
