Latest post Sun, Oct 25 2015 2:24 PM by pallen33. 37 replies.
Page 2 of 3 (38 items) < Previous 1 2 3 Next >
  • Mon, Jan 13 2014 3:37 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: C300 MXF & Media Composer Workflow
    Marianna:
    You should using:
    - Mac OS X 10.9 or 10.9.1
    - MC 7.0.3  ( making sure all OLDER versins and avid files are removed)
    - MSP_MXF Plug-In    1.10.1.6400   which is installed with the MC 7.x application
    - You need to manually install the Canon XF AMA plugin version 2.03
    Give Dom's suggestion a try and see if this works for you.
    Dom posted:
    FYI - I created a folder called "CanonC300" and placed the "CONTENTS" folder in there. I placed it in my root directory and AMA linked to the "CanonC300" folder.
    Report back
    marianna
    This was what surprised me as the OP seems to have same probs as I have and it´s working for both you and Dom
    Tomas
  • Tue, Feb 4 2014 12:57 AM In reply to
    • matthewh
    • Joined on Thu, Oct 24 2013
    • NY
    • Posts 95
    • Points 1,050
    I am trying to consolidate C300 clips (MC7.03 with latest canon plugin installed). Some 23.97 1080p and some 60fps 720p
    AMA link works fine but once consolidated the new mxf files wont let me export QT ref as they are still long GOP by the looks of the error message. I am instructed to do a custom export but not sure what this is
    It's making me think I should just transcode everythng to DNx115 (good enough for a quick grade in an emergency - i am doing several short commercial spots) and will relink to the originals in Resolve for the finals.
    4 GHz i7 Retina iMac, 24 GB 1600MHz DDR3, AMD M295X 4GB OSX 10.10 MC8.3 3.4GHz i7 iMac, 20 GB 1333MHz DDR3, AMD 6970M 1GB, OSX 10.9.1, MC7.04 [view my complete system specs]
  • Thu, Mar 6 2014 3:23 PM In reply to
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 142
    • Points 1,925
    Finally, I re-installed my whole system and everything seems to be working fine now! I really can't say what was wrong, as my folder structure is still the same. My guess is that my number of files was so big; it took Avid about 15-20min before I could see the "SCANNING" dialog box.
    For the record, because I have hundred of hours of footage from the C300, here is the folder structure I use  to keep track of every day of shooting that comes in:
    ROOT OF DRIVE / PROJECT NAME / SHOOTING LOCATION NAME / CARD 1 / CONTENTS / CLIPS001 / MXF'S
    I simply point AMA LINK (using “Autodetect AMA plugin from” the AMA LINK window) to my “PROJECT NAME” folder and it created BINs based on the sub folders.
    So far, with timelines averaging 45minutes, everything seems to be working fine. A little bit slow, but nothing I can't live with. I am still wondering about something:
    If my project become slower, will I be able to transcode my Canon MXF to something more “Avid friendly” and have my already edited sequences relink to those new files?
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
    Filed under: , ,
  • Fri, Mar 21 2014 5:36 PM In reply to
    • Gabriel
    • Joined on Wed, Dec 5 2012
    • Toronto
    • Posts 122
    • Points 1,400
    Glad it worked. Now is my time. I can't see to link to AMA with C300 footage. My system is PC windows 7.
    I can AMA link too BMCC DNxHD footage but I can't see to AMA link Canon C300 footage. I do have installed the canon XF 64bit plugin....
    My AMA settings are link to volume...
    My root drive is my internnal raid.  DATA (D:)/Phil Interview/A Cam/Roll1/CONTENTS/CLIPS001/BB3822
    I did try to put to "contents" folder on the root directory but still doesn't read it...
    I'm searching on old posts here, creative cow too and ashley Kennedy tuts but I can't see find a solution yet. Please, if anyone has a tip, please let me know. Thanks
    AMC 8.3 Dell Precision T7610,Windows 7 Pro 64 bit, 512 SSD Drive (C Drive), 9TB Internal Raid 0, 4TB External Raid 1, 24 Core Intel Xeon CPU ES-2630 @ 2.60 GHz, 32 Gb ram, Quadro K5000, BMD Decklink SDI 4K Card. Asus ProArt 246Q, Asus ProArt 249Q & FSI LM-2461W.
  • Fri, Mar 21 2014 5:50 PM In reply to
    You need to volume link to the "Roll1" folder. Basically, the folder ABOVE the CONTENTS folder.
    Try manually selecting the Canon AMA plugin during the AMA linking process. (Auto is the default)
  • Fri, Mar 21 2014 6:10 PM In reply to
    • Gabriel
    • Toronto
    • Posts 122
    • Points 1,400
    Yes!!! Thanks Dom.  What I did in the AMA settings, I created a new Bin called AMA Source Media and then in my file/AMA link I did what you told me. Files of Type: Canon XF Plugin 64 and File name: Roll1...and done..
    Thanks Again Dom...
    League
  • Fri, Mar 21 2014 7:02 PM In reply to
    It seems the latest Canon AMA plugin with MC 7.03 is unable to resolve linking when set to "Auto" and/or when the target virtual volume/folder is too deep.
  • Mon, Sep 22 2014 9:12 AM In reply to
    • John Roberts
    • Joined on Wed, Oct 26 2011
    • United Kingdom
    • Posts 23
    • Points 275
    I had the same problem...
    Download this for PC- http://support-au.canon.com.au/contents/AU/EN/0200213002.html
    Or this for Mac - http://support-au.canon.com.au/contents/AU/EN/0200213102.html
    Solved!
    HP z400 Intel Xeon CPU W3550 @ 3.07GHz 12gb Ram Windows 7 64-bit Media Composer 5.5 AJA io express [view my complete system specs]
  • Thu, Dec 18 2014 6:41 PM In reply to
    I have the same problem, tried everything but I guess the new Avids can't seem to read the C300 files natively in AMA (which is strange because my Avid 6 was reading them perfectly before I upgraded to 8.2. Now I can't even read the files in my timeline that I already made before I upgraded!)
    My workaround was simply Sorenson Squeezing them into ProRes 422 .mov files. Pretty unfortunate.
    AVID 8.3.0, Macbook Pro Retina - Processor 2.6 GHz Intel Core i7, Memory 16 GB 1600 MHz DDR3, Graphics NVIDIA GeForce GT 650M 1024 MB, Software OS... [view my complete system specs]
  • Thu, Dec 18 2014 7:22 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,235
    It appears that tne current Canon AMA plugin (v2.0.3) doesn't yet support MC 8.2, but rather only up to MC 7.  Camera manufacturers are responsible for updating their AMA plugins.
    Media Composer v8.9.2 | Windows 10 Professional 64-Bit | Supermicro X10DAi | Intel Xeon E5-2620 v4 Broadwell (x2) | Noctua NH-D9DX i4 (x2) | PNY GeForce... [view my complete system specs]
  • Thu, Dec 18 2014 7:25 PM In reply to
    Would this explain why 5D MKIII footage doesn't work well with AMA either? It's always freezing and bugging
  • Thu, Dec 18 2014 8:13 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,235
    Difficult to say without knowing your specs.  Could you fill out your profile with the relevent hardware specifications, similar to what I have in mine?
  • Thu, Dec 18 2014 8:30 PM In reply to
    Absolutely, thanks for the advice. I put down what I know under my profile
  • Thu, Dec 18 2014 9:24 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,235
    Assuming you're able to AMA the 5D clips into a bin, then the plugin is likely not the problem in this case.  Canon's DSLR clips can be pretty processor-intensive to play when only linked via AMA, however.  Most editors I know either transcode these immediately to some flavor of DNxHD or perhaps make selects from the AMAed clips and then transode these.
  • Thu, Dec 18 2014 9:32 PM In reply to
    It won't let me import or transcode them either. It freezes and does teh rainbow wheel of death after a few clips each time.
    Am I seriously going to have to just learn Premier and make the jump? At least a third of my work is on Canon and none of it will work for me (whereas it all worked fine with Avid 6 for me...)
    Or do you think maybe I should try re-installing Avid 8.2? Am I even allowed to, I have a yearly subscription and last time I tried to reinstall Avid they didn't let me. Nobody else has seemed to have any better luck when reinstalling it, but that's my only guess at this point. So discouraged about this, real bummer and I have a deadline to make right now.
