Latest post Wed, Dec 11 2013 1:02 PM by Yasmin F. 8 replies.
Page 1 of 1 (9 items)
  • Sun, Dec 8 2013 6:16 AM
    • Yasmin F
    • Joined on Sun, Dec 8 2013
    • Posts 5
    • Points 65
    Export 'same as source' problems
    Hello,
    I would really appreciate some help.
    I am trying to export my timeline throuhg export same as source. when I open the exported file it looks bad and has lines digital across across peoples faces when they speak, i think it looks interlaced. Sorry I am not sure what you call this, when lines appear acorss the video
    This issue has happened only since I recently updated the software.
    I am using Avid Media Composer Interplay edition 7.0.0 on a Mac OSX 10.8.2
    The timonlien is made up of clips that were first Ama linked that were then transcoded to Apple Pro Res
    When I export same as spurce a file is made, but it looks really bad.
    I have even tried exporting as Apple Pro Res and H.264 and ticked de-interlace source video but thats hasnt solved the probem.
    Any ideas or tips are much appreciated
  • Mon, Dec 9 2013 8:08 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,035
      Moderator: MCA Mac
    Re: Export 'same as source' problems
    Some more information would be helpful.  What is the frame rate and size of the source material?  What are the project settings?  Are you seeing the lines on the computer monitor or on a video monitor?  Can you post a screen grab of what you're seeing (if you're on a Mac, try Command-Shift-3).
  • Mon, Dec 9 2013 3:49 PM In reply to
    • Yasmin F
    • Posts 5
    • Points 65
    Hello hbrok,
    The source material frame rate is: 50i
    The prject setttings are:
    1080i/50
    Raster dimentions: 1920 x1080
    Its odd as this probelm has only happened once I upgraded, and I had projects with the same setttings earlier this year on Avid MC 6.5 and exported them same as source with no issues.
    I played around some more and when I put a timewarp effect on the clip (and made it export as progressive) the clips look 'normal' once I export them out of Avid. Is there a way to make all the clips looks correct in an easier way raher than add a time warp effect to everything?
    Have I set the project up wrong? Could that be it?
    Many many thanks!
  • Mon, Dec 9 2013 4:08 PM In reply to
    Ok with a 50i project you are telling Media composer to make interlaced content.
    If you load interlaced sources you will export interlaced outputs.
    Normally seeing interlaced artefacts on the export isn't an issue (if you wnat and need an interlaced export)
    And if you then need to make progressive files say for the web then just de-interlace in squeeze.
    If you actually need and want progressive outputs set MC to a 25P format and it will add motion adapters to interlaced content. Exports should then be fine.
  • Mon, Dec 9 2013 4:20 PM In reply to
    • Yasmin F
    • Posts 5
    • Points 65
    Hello,
    Thanks for the info, I will try setting the project to 25P instead of 50i and hopefully that will fix it!
    cheers!
  • Mon, Dec 9 2013 5:08 PM In reply to
    Yasmin F:
    It won't. If you're seeing interlacing issues now, it means your source footage is interlaced. You can deinterlace it at some point, depending on delivery requirements.
  • Tue, Dec 10 2013 4:08 PM In reply to
    • Yasmin F
    • Posts 5
    • Points 65
    Hi there,
    you are right that didnt work! I must admit I am new to this, how am I able to deinterlace the footage, is there any way to do that throuhg the export option? or must the exported film be put throuhg another program to de-interlace it?
    Many thanks,
  • Tue, Dec 10 2013 5:11 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,333
    • Points 60,235
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    I found a couple of links tht might be helpful.
    You can use the motion effects filter or BCC/Avid FX. Here is a tutorial on Boris...
    http://www.borisfx.com/tutorials/deinterlace.php
    ...or Sorenson Squeeze...
    Mac Pro. QHD Ultra wide, thunderbolt LG monitor, MC Ultimate 2018.10.0. Pro Tools 11 HD (Mbox 3 Pro), iPad Pro 12.9". 17" Macbook Pro i7. Dell... [view my complete system specs]
  • Wed, Dec 11 2013 1:02 PM In reply to
    • Yasmin F
    • Posts 5
    • Points 65
    Great thanks for all the advice, I got there in the end with timewarp.
