Latest post Sun, Nov 10 2013 10:33 PM by cineblue. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Nov 7 2013 4:30 PM
    • cineblue
    • Joined on Mon, Nov 21 2011
    • Posts 16
    • Points 225
    Using the McBeth color chart for color grading.
    So I started browsing the web looking for ways in which film makers have used the McBeth chart for video color grading.  I couldn’t find any.  Now I’ll be the first to acknowledge that a DSC Labs chart is the way to go, but I’ve been curious to find out if it can be done with the McBeth chart.  I came upon a solution that I think works pretty well so I created a tutorial.  Enjoy!!
    GoBoxx 1840, Geforce 675M (driver 310.90), i7 Extreme Quad Core, 16GB DDR3, WACOM Intinous 5, Windows 7 Ultimate SP1, Avid Media Composer 7, Avid DVD,... [view my complete system specs]
  • Thu, Nov 7 2013 4:50 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,323
    • Points 60,085
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Re: Using the McBeth color chart for color grading.
    Thanks... shared on facebook. :)
    Mac Pro. QHD Ultra wide, thunderbolt LG monitor, MC Ultimate 2018.10.0. Pro Tools 11 HD (Mbox 3 Pro), iPad Pro 12.9". 17" Macbook Pro i7. Dell... [view my complete system specs]
  • Thu, Nov 7 2013 5:53 PM In reply to
    • cineblue
    • Posts 16
    • Points 225
    Thanks! :)
  • Thu, Nov 7 2013 9:18 PM In reply to
    • Posts 10,018
    • Points 215,715
    That was a really interesting and well done tutorial.
    I have been lucky when shooting video and never really found I needed colour grading - believe it or not.
    Your tutorial explained a lot that will be of great use to me when I do find I need to start.
    Thank you for that effort. Yes
    Regards
    Douglas
  • Fri, Nov 8 2013 2:16 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,850
    • Points 24,220
    I very much enjoyed the tutorial, but have a question.  Does your method pre suppose that you need to include the color chart in each series of clips so that the lighting effects the subject and the chart at the same time?  How would you use your technique without the chart included in the video clip?
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Fri, Nov 8 2013 8:20 AM In reply to
    What you can do is look for objects in the image that should naturally be close to pure white and pure black. For example, the wall in the b.g. should most likely be pure white, so use that instead of the white chip on the chart.
    Thanks a lot Marco!
  • Fri, Nov 8 2013 3:05 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,850
    • Points 24,220
    If you look at the first frame of his post, the white on the card is no where near the white on the wall.  The wall appears to be an off white or pale yellow, and they are illuminated the same.
    Denny
  • Fri, Nov 8 2013 3:57 PM In reply to
    Well, that's not my fault, LOL! You have to work the best you can with what IS in the shot.
    Now if you are using the same setup, you don't need to shoot the card each time. You could just copy the grade you did for the shot that has the card in it.
  • Sun, Nov 10 2013 1:49 PM In reply to
    • newstudy
    • Joined on Sun, Nov 10 2013
    • Posts 7
    • Points 95
    I am a student in my first semester and just starting with MC7.  I hope this question isn't a stupid but why were your target values for white and black 200 and 40?  Shouldn't they in theroy be 255 and 0?
  • Sun, Nov 10 2013 7:30 PM In reply to
    It all depends on how bright you want white to be in the image and how dark you want the black to be. For exmaple, I'm looking around the room right now, and I don't see anything that is extremely bright white or extremely dark black.
    Also, realize that in the video world, black is 16 and white is 235. So depending on how your finished work is going to be delivered and displayed, everything below 16 and above 235 may get clipped.
  • Sun, Nov 10 2013 10:33 PM In reply to
    • cineblue
    • Posts 16
    • Points 225
    Hello everyone!  First I'd like to say thank you for all the feedback!  I'll try to answer as many questions as I can :)
    Douglas, I sincerely appreciate your comments.  I’m a huge fan of your tutorials and it’s great to have your feedback!
    dmfreeman:  This method does suppose that the lighting is fairly constant through your series of clips.  Mostly as long as the light type doesn’t change (tungsten, HMI, LED, sunlight) then all you have worry about is exposure and contrast.  It’s best used in a multicam environment, but as long as there aren’t any major lighting changes between camera shots it should work quite well to get your colors looking good.
    newstudy: The reason I went with 200 and 40 is because I’m trying to retain color information in shadows and highlights while grading to get the best possible readouts during my grading process.  If I went with the extremes 255 and 0 or 16 and 235 I may lose valuable color information during the grading process.  That’s why I adjusted my master (contrast) curve at the end.
    I forgot to mention this is the video, but you can also take additional samples in one of the midtone grey patches for even more accurate grading.
    Good luck and thanks again for all the feedback!
