Latest post Tue, Nov 12 2013 5:06 PM by slabross. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Nov 7 2013 10:16 AM
    • Rory Gavin
    • Joined on Fri, May 10 2013
    • Ireland
    • Posts 9
    • Points 145
    DS 11.1.1 Generate Snapshot to Clip issue?
    We recently upgraded to DS 11.1.1 and I'm getting an error when I try to generate a snapshot to clip - The DS is advising me that "The selected video storage cannot be used for capturing since it is read-only."
    But the storage isn't read only.
    Anyone having a similar issue?
    Avid DS 11.1.1/Sapphire/Tinder. HPXW8600 16GB/14TB. [view my complete system specs]
  • Fri, Nov 8 2013 6:29 PM In reply to
    • slabross
    • Montreal, Quebec, Canada
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    Re: DS 11.1.1 Generate Snapshot to Clip issue?
    Open the Process dialog and verify the storages list.  Is a read-only storage listed by default instead of a read and write one?
    The same can be checked under Data Management, open Configure Storage... You access the storages list and you verify if a read-only storage is at the top of the list. You can select and lower its priority so a read and write storage always be used first. It's actually best.
    Sylvain Labrosse
    Principal Expert | Services and Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    Create cases online now at  csportal.avid.com
    It's fast, easy and effective!
    We're Avid.  Learn more at www.avid.com
  • Mon, Nov 11 2013 9:52 AM In reply to
    • Rory Gavin
    • Ireland
    • Posts 9
    • Points 145
    Hi Sylvain,
    Thanks for the reply.  I've double checked and none of my storages are read-only unfortunately.  It doesn't make any difference which drive I select.
    I'm running DS 11.1 on a HP XW8600 with Windows 7 Pro, using an Avid Videoraid SR.
    Thanks again,
    Rory
  • Mon, Nov 11 2013 7:20 PM In reply to
    • slabross
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    I'll check on a few different systems but it works on the DS Software I tried, although not using a true media storage.
    Sylvain Labrosse
    Avid
    Canada
  • Tue, Nov 12 2013 1:40 PM In reply to
    • Rory Gavin
    • Ireland
    • Posts 9
    • Points 145
    Hi Sylvain,
    It's working!  I disconnected from all the storages using Configure Storages and then reconnected.  The generate snapshot function started working straight away.
    Many thanks for looking at this,
    Rory
  • Tue, Nov 12 2013 5:06 PM In reply to
    • slabross
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    Ha, good!  I can only assume that there was an incorrect configuration in the settings and your steps helped clear the problem.
    Glad that you are fully operational again.  Wink
    Sylvain Labrosse
    Avid
    Canada
