I own a MBP for mid 2009 with LION, internal drive is 7200 rpm , 2.66 ghz, 8gb ram and NVIDIA GeForce 9400M 256 MBi run on it final cut 7 and fcx, have many problem with apple motion on hd motion graphic project, My question is if can approach to avid media composer 6 at least to study it.probalby I will have to replace my internal drive beacuse it is starting to give some problem, I have found a sdd drive at a convenient proice but it is 5400 rpm, what drive do you suggest to replace with? for project files i use a graid fw 800 2 tera
Ali.......
MC 6.0.5 for example which is the latest in that code base - works with
Lion 10.7.4, 10.7.5 as well as Mtn Lion 10.8.2, 10.8.3 and 10.8.4
You might have an issue with Limited HD playback but you should be ok. The rub here is that we dont sell MC 6.x any longer but if you go on the Download Center - you can download and try it. http://esd.avid.com/ProductList.aspx
Twitter: avidmarianna
www.avidcustomerassociation.com | Connect 2019 | April 6-7 | Aria, Las Vegas, NV
I run MC 6.5 on almost that exact same system, MBP mid 2009, running 10.8.4. I have the 2.8 GHz processor rather than 2.66 - otherwise, I think you might have an identical system.
System drive, if you can find something like a 7200 RPM hybrid drive, that can be a nice boost. Me, I have a 750GB 7200 RPM hybrid system drive, and I also replaced the optical drive with a second internal hard drive for media - 750GB, 7200rpm HDD - not hybrid.
Works pretty well - I don't do much HD on it, lots of DV. I'll often use it as a way to continue on projects that I start on my main system at home. I'll transcode my raw video to something like 15:1 to save space, put it on the laptop, and edit. If I have more space available at any given time, maybe I'll use DV, or maybe a lower-grade DNxHD.
But in general, yes - I'd say you can use it to experiment and learn. Install the trial, and see how you like it!
usatraveler: and I also replaced the optical drive with a second internal hard drive for media 750GB, 7200rpm HDD - not hybrid. Works pretty well - -
Works pretty well -
optical drive you mean the cd/dvd burner? how can the drive stay there
ok i am seeing it on youtube
I too have that same unit as my render farm and I have a wd 4 tb studio raid attached via usb and its solid
Tom Pearson
It seems hard on the on the on line store where i usually make my purchases to find a sdd 7200 rpm, but there are a lot of 5400 sdd good deals, there is a differences noticeable? theres an improvment between an 7200 rpm (not hybrid) with a 5400 sdd?
