Latest post Tue, Oct 15 2013 10:54 PM by Marianna. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Oct 15 2013 10:56 AM
    • Callum
    • Joined on Tue, Oct 15 2013
    • Glasgow
    • Posts 10
    • Points 130
    Running AVID 6.5 on Non-qualified PC
    Hi Community, this is my first post
    Our old qualified AVID machine packed it in the other day and rather than shedding out $4000 for a new one I've put together a build. What issues do you think I could hit along the way with this build:
    Intel i7 3770k 3.5 ghz
    ASUS P8Z77-V LX2 Motherboard
    8 Gig DDR3 Ram
    Quadro 1500 GPU
    850Watt PSU
    Avid 6.5
    Windows 7 64-bit
    No I/O etc, just software.
    Windows 10 Pro 64-bit 2xIntel Xeon E5 v3 @ 2.60GHz (Dual CPU) 64gig RAM 4gig NVIDIA Quadro K5200 Hewlett-Packard 2129 Motherboard [view my complete system specs]
  • Tue, Oct 15 2013 12:01 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,347
    • Points 16,570
    Re: Running AVID 6.5 on Non-qualified PC
    There are no guarantees with an off-spec system, and it might be harder to get help if something goes wrong.
    That being said, as long as your windows 7 is pro or ultimate, that will likely work.
  • Tue, Oct 15 2013 12:31 PM In reply to
    • Posts 10,022
    • Points 215,755
    cwarre14:
    Quadro 1500 GPU
    If you mean the Quadro FX 1500, there were known problems with Avid FX when running any Quadro FX cards that had a number ending in 500,
    I have an FX 3500 and an FX 3700.  The 3700 has never had any problems, the 3500 has.
    The FX 1500 had similar problems and the FX 1700 did not.
    Now that was about 2 or 3 years ago.  I am almost certain that any problems have been ironed out either in Nvidia drivers, or in the Avid FX application or even in MC.
    I have not seen any problems with the latest versions together with my FX 3500 recently.
    So this is not necessarily an issue nowadays. I just wanted to let you know.
    Regards
    Douglas
  • Tue, Oct 15 2013 1:16 PM In reply to
    • Posts 10,022
    • Points 215,755
    Welcome ...  the 2 posts are spot on and as long as you use the right OS, drivers and are aware that milage may vary since it isnt a approved system, you should be ok.
  • Tue, Oct 15 2013 9:32 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,321
    • Points 53,415
    The Quadro Fx1500 does not have enough memory. You should consider a K600. You need at least 1 gig video memory, the 1500 has 256meg.
    http://www.bhphotovideo.com/bnh/controller/home?O=&sku=992412&is=REG&A=details&Q=
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Tue, Oct 15 2013 10:54 PM In reply to
    • Posts 10,022
    • Points 215,755
    TVJohn:
    A very good observation, John!
    Regards
    Douglas
