Latest post Sun, Oct 13 2013 6:57 PM by Vilem. 2 replies.
  • Sun, Oct 13 2013 3:39 PM
    • Mattias
    • Joined on Sun, Oct 13 2013
    • Antwerp
    • Posts 1
    • Points 25
    32fps in Avid Media Composer 7
    I'am currently editing a videoclip that has been shot on Red 3K at a framerate of 32. My goal is to keep my 32frames in Avid Media Composer. I tried multiple options: First I imported the clips using Ama and kept my 32frames in a 25fps project, but I need to timewarp the images and I cant add the timewarp effect on my Ama clips. So I tried to transcode my Ama files but it automaticly change my frame rate to the project frame rate: so 32fps becomes 25fps. I converted my R3D files with RedcineX to QT DNX 185 and kept my 32frames. When I tried to import the DNXclips MC changes all my frame rates to 25fps. Is there a way to import 32fps footage into an 25fps project?
    I would be very happy if someone could help me.
    Thx
  • Sun, Oct 13 2013 5:39 PM In reply to
    Re: 32fps in Avid Media Composer 7
    MC doesn't support 32fps.
    So if you want to work in MC you will have to frame rate convert.
  • Sun, Oct 13 2013 6:57 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,405
    • Points 15,470
    Mattias:
    Insert the clip into the sequence and use the "erase" effect. MC will play back images by setting the project (25) - in your case slow motion.
    The sequence can consolidate / transcode and get native codec in MC.
    You can insert a timewarp effect and set you need.
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
