Latest post Sun, Nov 9 2014 1:29 AM by jef. 6 replies.
Page 1 of 1 (7 items)
  • Sat, Oct 5 2013 4:36 AM
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    MOCHA AE and Black Screen with DnxHD codecs
    Anyone having issues with Qt refs or quicktime DnxHD files  (Avod Codecs 2.3.9) showing black screens in Mocha AE after import?
     Mocha support thinks it's Avid Codecs 2.3.9?
    HP Z800 MC 8.3, Adobe CC, Windows 7 Ultimate 64-bit SP1, 2 Hex Core X5650 @ 2.67GHz, 48Gigs Ram, NVidia Quadro K4000, Sandisk Extreme 240 gig SSD System... [view my complete system specs]
  • Sat, Oct 5 2013 8:47 AM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 155
    • Points 1,900
    Re: MOCHA AE and Black Screen with DnxHD codecs
    After the same issue but on Mac side of Avid I was forced to transcode export clips to Prores.
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Sat, Oct 5 2013 2:50 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 1,030
    • Points 13,055
    I've also had this problem under Win 7.
    I posted this very  same question on a recent, live webinar (by Imagineer systems) on Mocha AE, and they didn't know.
    Given that Quicktime player ,VLC, Sorenson Squeeze, After Effects, Premiere etc  will all play my  QT DNX files, I think their support needs to explain why Mocha cannot successfully decode them, rather than blaming the Avid codecs,
    I've had to resort to exporting using the animation codec.
    Bruno
    HP Z800, HP G9 Fury, SonnetFusion RAID, Mojo DX, Decklink 4K, Ultrastudio 3G, Symphony 2018 & 2022, Boland BVB25 OLED, JVC DTV1910 HD CRT, Eizo ColorEdge... [view my complete system specs]
  • Sun, Oct 6 2013 3:05 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    I agree. Mocha worked with Avid codecs 2.37 (all clips I have that were with 2.37 work), but after 2.38 DnxHD stop working. Mocha does need to fix this since DNxHD (2.39 codecs) works with all Adobe products, VLC and others.
    I miss being able to export a QT reference file for Mocha to track instead of exporting a full file that takes up more space on my video drives. I'm glad I wasn't the only one having this problem.
  • Mon, Oct 7 2013 3:51 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Yeah, Micha support just wrote me back:
    Here is the message that has just been posted:
    This appears to be an ongoing issue with any Avid codec above 2.3.7.  We have the problem logged, but have as yet been unable to build a solution.
    The only workaround at present is to install the 2.3.7 codecs or convert the output to a different format.  We apologise for this, as obviously this takes time and is not ideal.  We will continue to investigate the issue.
  • Sat, Nov 8 2014 10:25 PM In reply to
    • Zach Fine
    • Joined on Thu, Mar 31 2011
    • Posts 47
    • Points 525
    One year later, and still black in Mocha AE for dnxhd. Unfortunate.
    Media Composer 2021.3 OS X 11.2.3 Late 2013 MacPro 3GHz 8-Core 128Gb RAM D700 GPU [view my complete system specs]
  • Sun, Nov 9 2014 1:29 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,147
    • Points 49,980
    Yes.  Chatted with them.  It is unfortunately a low priority as there are workarounds.  I generally just make an animation codec copy to send to Mocha.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2023.3.1 iMac w Big Sur and 2018.12.7 on Windows 10 Boot Camp [view my complete system specs]
    Jef Huey
