Latest post Sat, Sep 14 2013 9:52 AM by DSLRMAN. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Sep 13 2013 11:40 PM
    • DSLRMAN
    • Joined on Tue, Apr 19 2011
    • USA
    • Posts 125
    • Points 1,795
    What is the best and fastest way to import/work Canon 60D files in AMC7?
    Can I just bring them in as AMA Link files and output the project?
    I know this sounds silly but, I had to convert them to ProRes to work in FCP7...
    Do I have to do anything similar in AMC7? I mean, do I have to convert them to ProRes and then bring it in as AMA?
    I'm using Mac Pro 8 Core / 24GBRAM / 1GBVRAM / Dual 24" Monitors
    Z
    Hardware: Mac Pro 8 Core, 24GB RAM, 4TB HD, Dual 24" Monitors - iMac 24" 3.06GHz Intel Core 2 Duo Software: Avid Media Composer 7 - Final Cut... [view my complete system specs]
  • Sat, Sep 14 2013 12:21 AM In reply to
    Re: What is the best and fastest way to import/work Canon 60D files in AMC7?
    You can use them immediately when you AMA link. But it is not recommended unless your timeline is simple and short. Ideally, you want to transcode them to DNXHD.
  • Sat, Sep 14 2013 12:23 AM In reply to
    • DSLRMAN
    • USA
    • Posts 125
    • Points 1,795
    In other words, regularly import them?
    The project is over 1 hour length...
  • Sat, Sep 14 2013 12:24 AM In reply to
    • DSLRMAN
    • USA
    • Posts 125
    • Points 1,795
    I have over 8 hours of footage... so the best way recommended is to import and transcode them to DNXHD?
  • Sat, Sep 14 2013 12:52 AM In reply to
    DSLRMAN:
    No, AMA link first then TRANSCODE. This will be faster than regular import.
  • Sat, Sep 14 2013 1:00 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,025
      Moderator: MCA Mac
    The best way is to AMA the original footage and then transcode to a suitable DNX or ProRes codec.  With AMA you can relink back to the original footage if you need to transcode the final sequence to a different codec if necessary.  If you import the only way to change the codec of the imported footage is to reimport ALL of any clip in the final sequence rather than just the parts of a clip that end up in the final sequence.
  • Sat, Sep 14 2013 1:27 AM In reply to
    • DSLRMAN
    • USA
    • Posts 125
    • Points 1,795
    Let me understand this a little better.
    So if I AMA all the footage, create a sequence, does it relink and transcode to DNX or ProRes only clips from In-Out on the timeline?
    In other words, I'm saying that If I have a clip that's 30sec long in the AMA Bin and I only use 10sec of that clip on the timeline, will it only transcode (DNX or ProRes) 10sec of the timeline clip used?
    Thanks again,
  • Sat, Sep 14 2013 2:00 AM In reply to
    DSLRMAN:
    Yes, if you transcode the sequence or a clip with an I/O point, it will only do that section.
  • Sat, Sep 14 2013 2:42 AM In reply to
    • DSLRMAN
    • USA
    • Posts 125
    • Points 1,795
    WOW, that's COOL !!!!!
    Thank you so much ya'll
  • Sat, Sep 14 2013 2:47 AM In reply to
    • DSLRMAN
    • USA
    • Posts 125
    • Points 1,795
    So do I just set my I/O the whole sequence then Right click on the Sequence in the bin and choose Relink?
  • Sat, Sep 14 2013 3:11 AM In reply to
    DSLRMAN:
    That depends on several things. Are your media in your timeline AMA linked media (yellow clips in the bin)? If yes, then all you have to do is right click the sequence in the bin and select Consolidate/Transcode. Select Transcode, choose your drive, set handles (extra frames beyond the used portion), select the format and transcode.
    it will create a new sequence along the transcoded version of the clips.
  • Sat, Sep 14 2013 9:52 AM In reply to
    • DSLRMAN
    • USA
    • Posts 125
    • Points 1,795
    Thank you so much...
