Latest post Tue, Sep 10 2013 6:55 AM by mjolnarn. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Aug 26 2013 8:17 PM
    MC Trial restrictions.
    I was just wondering. At the time of MC5 and before the trial versions would expire when opening a project that was older then 30 days. Is this still the case in MC 6.5 and MC7?
    Jeroen van Eekeres
    www.mediaoffline.com
  • Mon, Aug 26 2013 8:59 PM In reply to
    Re: MC Trial restrictions.
    This doesn't make sense, a trial version expiry date is determined by files in the registry, not by opening an old project, I don't recall seeing this behaviour, AFAIK it isn't a problem.
    :: Work - Symphony Nitris DX 3.5.1, HP xw8600 :: Home - Intel 3.0Ghz Quad CPU 8GB G.Skill DDR3 7-7-7 1600 Ram Asus P5E3 Pro NVidia Quadro FX... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Mon, Aug 26 2013 9:07 PM In reply to
    Scott Carnegie:
    I have seen many posts where the trial period is shortened or invalidated by opening old project / bins from older projects. So I think there is an issue here.
  • Mon, Aug 26 2013 10:03 PM In reply to
    It was definitly an issue in the trials of MC 3.5, MC 4 and MC 5. But it was never clearly stated in the trial FAQ or any other document. Now with an MC7 trial I have been able to open older projects and did not see any issue. But that doesn't mean that they are not there. With MC 6 and 6.5 I'm not sure.
    I'm asking cause I've been asked to upgrade a vista + MC4 system to Win 7 + MC6.5.3 but for economic reasons the order of the new license will take 2 weeks or so. Will the trial open all of the multiple years old projects that are on this machine?
    Of course I have the option of creating images of the OS and MC.. or replacing the OS drive with a new one, but it would be nice to be sure before I do a "format c:".
    Jeroen van Eekeres
  • Tue, Aug 27 2013 5:37 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,381
    • Points 96,975
    Because of a dongle fault I had to run MC7 for some weeks in trial mode.  I was working with an old project part of that time, and it didn't cause me any problems.  Everything just worked.
    But I'd still definitely create an image if you're going to do a clean install.
  • Tue, Aug 27 2013 6:11 AM In reply to
    Thx John, That's what I wanted to know. I will definitely create an image.
    Remains the questions why Avid does not mention this in the trial FAQ?
    Jeroen van Eekeres
  • Tue, Aug 27 2013 8:01 AM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    We did never manage to install any AMA plugin to our trial-version.
    Is it suposed to be a limitation.
    Did anny managed?
    13 edit stations Educational MC 6.5.2 in use, MC 6.5.3 under reliability test, MC 7 under consideration workflow test, dongles with troubles, AVID ISIS... [view my complete system specs]
  • Tue, Sep 10 2013 1:03 AM In reply to
    • mtahir
    • UK
    • Posts 480
    • Points 5,865
    Is there an official list of what the limitations are, if any, on the MC7 trial? Also, when does the tiral begin - from install or is it when you activiate the trial?
    MC2018.1 (Win7) | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 64GB (32GB per CPU) 1333MHz DDR3 EEC FBDIMM | 3GB nVidia Quadro... [view my complete system specs]
    Filed under: ,
  • Tue, Sep 10 2013 6:02 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    mtahir:
    No limitations at all, it just will stop working after 30 days of the install.
    Also, be sure to use the latest certified ama plugins, avid.com/ama and to do a clean uninstall of 6,5 or earlier removing all of the old ama plugins also if that means to manually trash some old Avid folders or files situated into those folders.
    Tomas
  • Tue, Sep 10 2013 6:39 AM In reply to
    • mtahir
    • UK
    • Posts 480
    • Points 5,865
    Thanks for the info. And the time starts once you install - there is no trial activation screen like the Adobe stuff?
  • Tue, Sep 10 2013 6:55 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    First time you open it up you get an option to run it in trial mode and then it starts to count down, I actually don´t know if it starts to countdown already at the initial install, once you have it installed you might to want to start try it anyhow, if you aren´t going to try it at once there might not be any need to install it until you have the time to try it  .Smile
    Tomas
