Latest post Mon, Oct 1 2018 4:13 PM by apeshake. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Jun 24 2013 10:12 PM
    Move selected clip to playhead shortcut
    Subject line says it all.
    Daytime Gig Gear Hardware: HP Z820 32gb ram • AJA Kona LHi • Xtore 5tb RAID • NVidia Quadro 5000 • JVC 24" HD-SDI monitor • Avid Artist Color &... [view my complete system specs]
  • Mon, Jun 24 2013 10:17 PM In reply to
    Re: Move selected clip to playhead shortcut
    [edited] never mind; I read it wrong.
  • Mon, Jun 24 2013 10:21 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,353
    • Points 16,640
    I agree Carl. Despite OP's insistence to the contrary, the question can be read a number of ways.
  • Mon, Jun 24 2013 10:25 PM In reply to
    OP here.  Ok. I'll spell it out.
    I would like to see a keyboard shortcut(s) that would move the head/tail of a selected clip to the playhead.
  • Tue, Jun 25 2013 12:45 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,381
    • Points 96,975
    Like the current Extend Edit but without needing to mark, you mean?
  • Tue, Jun 25 2013 1:12 AM In reply to
    Not exactly. The extend shortcut trims. I would like to select a clip, position the playhead and hit a shortcut to move the clip in its entirety (not changing duration or in/outs) to the playhead position.  I used to run a NLE named Velocity that had this shortcut and I found it very useful.
  • Tue, Jun 25 2013 1:40 AM In reply to
    • smrpix
    • Posts 1,353
    • Points 16,640
    The closest I can think of is you position the playhead, select the clip with the red or yellow arrow segment mode,  then
    Ctrl + drag segment in Timeline to snap head to playhead, (Mac Command + Drag)
    Alt + Ctrl + Drag to snap tail to playhead.  (Mac Option + Command + Drag)
  • Tue, Jun 25 2013 2:22 AM In reply to
    I knew the CTRL-DRAG method. That`s why I posted in Feature Requests.
  • Tue, Jun 25 2013 5:04 AM In reply to
    • smrpix
    • Posts 1,353
    • Points 16,640
  • Tue, Jun 25 2013 5:10 AM In reply to
    SamDogDigital:
    It's a good request, just like having the ability to type Enter to move a highlighted segment(s) plus or minus the last numeric-keypad amount used would also be a good request. (same way Trim works and the way cursor movement works)
    In the meantime- you could highlight a clip on timeline, press Alt+Z to lift it off the timeline into the Source monitor, re-position your cursor anyway you like to get to your intended spot, then press Alt+ B or Alt+V from the source side to overwrite or splice edit at your new cursor position.
    I think that may work for you.... sort of.
  • Mon, Oct 1 2018 4:13 PM In reply to
    • apeshake
    • Joined on Wed, Mar 20 2013
    • Posts 13
    • Points 175
    +1, I don't suppose this feature has been added since 2013? Would be very handy for music edits
