Latest post Tue, Jun 18 2013 6:59 PM by Vilem. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jun 13 2013 4:39 PM
    • Wes Torain
    • Joined on Mon, Feb 22 2010
    • Huntsville-Decatur Alabama USA
    • Posts 61
    • Points 830
    MC 6.0.1.1 and AJA KiPro
    I'm doing a 3 camera production using Panasonic HMC 160 cameras, feeding into a Panasonic HWHS50 HD switcher, recording to KiPro and editing in AVID MC 6.0.1.1
    I'm told I will need to purchase and download MacDrive Standard software plugin in order for AVID to read the KiPro drive...then link to AMA and Transcode to DNxHD 145.  Is this the most effecient workflow for my hardware or is there a better way?
    Dell Precision T7610-64bit Dual Quad Core Intel Xeon Processors Windows 7-Media Composer 8.3.1 QuickTime 7.7.9 32GB RAM - NVIDIA Quadro FX 3800 Boot Hard... [view my complete system specs]
  • Thu, Jun 13 2013 4:53 PM In reply to
    Re: MC 6.0.1.1 and AJA KiPro
    Check the KiPro firmware version - newer versions can transfer files over ethernet, thereby negating the drive-format issue.  Give that a try, following the directions in the KiPro manual.
  • Thu, Jun 13 2013 6:27 PM In reply to
    • Ben Wilson
    • Joined on Thu, Jun 10 2010
    • Columbia, SC
    • Posts 218
    • Points 2,500
    If you are pulling the drive module out and connecting via firewire, then yes, you will need MacDrive.  These are HFS+ (MAC) formatted drives.  I recommend transferring the file to an NTFS formatted drive first and then AMA linking.   OR just simply import.  I have had instances where I could AMA link to files on Mac formatted drives via MacDrive, but they wouldn't show the content of the files.  I would have to transfer the files first to an NTFS drive, then link.
    Several. 1x MC7.0.4 HP z800 dual XEON x5650-2.66GHz 12MB Ram Quadro FX3800 NitrisDX. 4 TB GSPEEDes storage. 2x MC 7.0.4 HP z420 MatroxLE. GSpeedQ 8TB... [view my complete system specs]
  • Thu, Jun 13 2013 7:33 PM In reply to
    • Wes Torain
    • Posts 61
    • Points 830
    Thank you, I'll check that.
  • Tue, Jun 18 2013 6:13 PM In reply to
    • Wes Torain
    • Posts 61
    • Points 830
    Aditional Help Needed!
    The video from the KiPro drive linked to AMA just fine.  I transcoded video to DNxHD 145...The editing was nice and smooth.  But now I've run into a problem after exporting my timeline as a Quicktime reference...the audio is slightly out of sync with the video...about 1 second off, just enough to notice and drive me nuts.  Any ideas!
  • Tue, Jun 18 2013 6:59 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,403
    • Points 15,450
    According to the specifications you have completed QT version 5.6.9. The MC6 is, I think, supported version 7.7 Thus I began.
    Then, as a licensee MC6 you can install it with the repair MC6.0.3 and patch MC6.0.3.4. This is another option.
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
