Latest post Mon, Jun 3 2013 5:34 PM by Tom Cook. 15 replies.
  • Sun, Jun 2 2013 2:00 PM
    • Tom Cook
    • Joined on Sun, Apr 25 2010
    • Keene, NH
    • Posts 180
    • Points 2,290
    MC6.5 and AVCHD Import?
    Folks:
    As always, thanks for the great forum and whatever help you might provide. Here's my issue today -
    I recently purchased a Sony NX70U HD camcorder which stores files in AVCHD format. One minor issue is that it seems to record in bursts of a few minutes, so if I'm recording an interview it saves for let's say three minutes then breaks into another save file, and I lose a second or two of the shot/interview. If anyone knows the NX70U, is there a way to make it record in a single clip?
    Of MUCH greater importance to me is that I was told Media Composer 6+ would import native AVCHD, eliminating my need to transcode the original AVCHD files into Quicktime (which seems to lose sync and is a hassle anyway). Well, I bit the bullet and bought MC6.5 but when I try to import the native AVCHD files Avid says, "This type of MPEG file is not supported."
    Great! Buy a program for the sole purpose of importing a certain type of file (told by Avid it would work) and it doesn't. Suggestions?
    Thanks! Tom
    Dell XPS720, quadcore 3.6 GHz, 28 GB RAM, Avid Media Composer v8.7.2 [view my complete system specs]
    Filed under: , ,
  • Sun, Jun 2 2013 2:26 PM In reply to
    Re: MC6.5 and AVCHD Import?
    "... when I try to import the native AVCHD ..."
    Importing takes too long.  Instead, AMA Link to the files.  You'll need to download and install the AVCHD AMA Plugin.  If the clps don't play smoothly (sytem specs determine this) you can Transcode them into DNx,
    (wwld)
  • Sun, Jun 2 2013 3:51 PM In reply to
    • Tom Cook
    • Keene, NH
    • Posts 180
    • Points 2,290
    Thanks. Will try right away.
    Tom
  • Sun, Jun 2 2013 4:11 PM In reply to
    • Tom Cook
    • Keene, NH
    • Posts 180
    • Points 2,290
    Randall:
    Okay, downloaded and installed the AMA Plugin per your link (thanks) but when I try to "Link to AMA file(s)" I get an error saying Avid is "Unable to link to file or volume" and that I "...may need to download & install the AMA plug-in from the Avid AMA website. See Console for more information."
    Initially I had my AVCHD files stores on a regulr hard drive, so (thinking speed might be an issue) I copied them to my SSD drive but still get the same problem. The guides mention I will need to perform a one-time activation of the Dolby AC-3 codec, but I can find no means of performing this...?
    Sorry to be lame, but any other suggestion to contionue this venue?
    Tom
  • Sun, Jun 2 2013 5:51 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Just bumped an old thread of mine, might be helpful
    Link
    Tomas
  • Sun, Jun 2 2013 6:06 PM In reply to
    Running a quick search in the help file for Dolby AC-3 codec  returns basic instructions on how to license the codec for use.
    Media Composer 8.2 Dongle+Symphony Option Win7x64 Pro HP zBook 15" Laptop - 16GB RAM (2nd System) Media Composer 8.2 Dongle+Symphony Option - HP z420... [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Sun, Jun 2 2013 8:55 PM In reply to
    • Tom Cook
    • Keene, NH
    • Posts 180
    • Points 2,290
    FD: Thought I'd certainly tried that but will endeavor again. Relative to mjoinarm's bump, I followed Tomas's recommendations and still get an error saying Avid cannot link to any clips... Still searching for solutions... Tom
  • Sun, Jun 2 2013 10:50 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,365
    • Points 16,830
    Are you shooting SD resolution?  Your error messages and problems are consistent with that.
  • Sun, Jun 2 2013 11:07 PM In reply to
    • Tom Cook
    • Keene, NH
    • Posts 180
    • Points 2,290
    Hmmm. I don't believe so (hadn't known/thought shooting SD was an option with an HD camcorder - especially if the files saved are AVCHD...)? Now, the files I am using for my test are not originals - I downloaded the master files from my SD crad, saved them to a media drive/fodler, then mad e backup of THAT folder to a BluRay data disk. After wiping my drive, installing MC6.5, I copied a few of those backed up on BR to my media drive and have been trying to import/AMA link thos with no success...?
    Tom
  • Sun, Jun 2 2013 11:37 PM In reply to
    • smrpix
    • Posts 1,365
    • Points 16,830
    It can.  The individual files may have an .mpg extension instead of .mts
    That's a very circuitous route, but as long as you kept the folder structure intact that shouldn't be the problem.
  • Mon, Jun 3 2013 12:26 AM In reply to
    • Tom Cook
    • Keene, NH
    • Posts 180
    • Points 2,290
    Yes, it is circuitous - not my normal way of doing things but figured it might suffice for a test. They files DID retain an .mts extension... Thaniks again for the suggestions.
    Tom
  • Mon, Jun 3 2013 3:43 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Tom Cook:
    Did you see this post of mine
    also notice that 1080 50p and 1080 60p not is supported, Squeeze is free with the 64 bits Avid to do that conversion
    Tomas
  • Mon, Jun 3 2013 3:35 PM In reply to
    • Tom Cook
    • Keene, NH
    • Posts 180
    • Points 2,290
    Yes, just checked my authorizations and saqw that Squeeze was available to authorize with MC6+. Am working with Avid now to figure out how to do that.
    Thanks for the assists!
    Tom
  • Mon, Jun 3 2013 4:51 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Tom Cook:
    Tom
    You´re welcome, with 6,5 Avid introduced the J2k codec that supports 1080 50 and 60 p, you might want to use that codec in Squeeze when you transcode your media.
    Tomas
  • Mon, Jun 3 2013 5:15 PM In reply to
    "... working with Avid now to figure out how to do that ..."
    You can get your Third Party Licenses here.
    (wwld)
