Latest post Sat, Jun 1 2013 5:58 AM by jwrl. 3 replies.
  • Fri, May 31 2013 7:07 PM
    • aedwurd
    • Joined on Sat, May 25 2013
    • Posts 53
    • Points 795
    Saving Custom transitions with different times?
    I have been customizing and saving transitions in Avid MC 6 at one second a piece. Is it possible to save the same customizied transtion at one second, 2 seconds, and 3 seconds? I use the same effect a lot, but sometimes I need a 1 second or a two second version of it.
    How can I save the same transtion with different times and save them as favorites?
  • Fri, May 31 2013 7:40 PM In reply to
    Re: Saving Custom transitions with different times?
    Create a bin named "Quick Transitions". Create any type of transitional effect you want and drag it to that bin. From that point on, when you launch the quick transitions window, those effects will be listed in the quick transitions pulldown menu.
  • Fri, May 31 2013 7:50 PM In reply to
    • aedwurd
    • Posts 53
    • Points 795
    That's what I have been doing, but I would like to save a cross dissolve as 1 second favorite, and a 2 second favorite.
    I want to do this so when I want to use a 2 second cross dissolve, I dont have to put a 1 second dissolve then go into the Quick transition dialog box and change it to 2 seconds.
    I just want to put it bewtween clips and not have to touch it.
  • Sat, Jun 1 2013 5:58 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,453
    • Points 98,470
    You certainly can.  Rename the 1 second version of "CustomTransition" to "CustomTransition_1sec".  Then open it again, change it to 2 second duration, drag then new version into Quick Transitions and rename it to "CustomTransition_2sec".  Done.
