Latest post Tue, May 14 2013 7:14 PM by slabross. 2 replies.
  • Tue, May 14 2013 9:14 AM
    • JohnnyDUK
    • Posts 5
    • Points 55
    DS Started dropping frames
    Hi All
    Our DS 10.3 has started dropping frames on playout to SR, i have attached a different raid and it is doing the same thing, any pointers as to what might be the cause, I have changed the SFP on the 41 ES and reseated all cards in the bob and the 8400. Also on ingest it gives a HAL error which I guess is a result of the same problem  ?
    JD
  • Tue, May 14 2013 7:03 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,413
    • Points 41,200
    Re: DS Started dropping frames
    Have you double checked that Storage Configuration has not changed to something like Generic?
    Jef
    Jef Huey
  • Tue, May 14 2013 7:14 PM In reply to
    • slabross
    • Montreal, Quebec, Canada
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    Check Configure Storages... as Jef suggest and, if not that, check the W light on the lower right side of the DS interface and park your mouse cursor on top of it.  A tooltip will pop and tell you the DS services status.  Check if the Media Indexer.  It must be Idle.  If it is Scanning, you cannot play media optimally in this condition and you must troubleshoot the services and the storage.
    Best, call Avid Support if you are stuck on this issue.
    Sylvain Labrosse
    Principal Expert | Services and Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    Create cases online now at  csportal.avid.com
    It's fast, easy and effective!
    We're Avid.  Learn more at www.avid.com
