Latest post Mon, May 13 2013 5:48 PM by mjolnarn. 7 replies.
  • Mon, May 13 2013 12:12 PM
    • S.Clements
    • Joined on Sun, Jul 3 2011
    • London, United Kingdom
    • Posts 809
    • Points 10,720
    HD/SD yellow-coloured clips in timeline of AMA project?
         I'm working with a project where all the clips are entirely AMA HD 1080p 25fps.  When I started editing, all the clips were the default green colour.  But then, at some point, I think I had to relink and many of the clips in the timeline turned to the HD/SD yellow shade clip colour.  I match framed both yellow and regular coloured clips to the bins and analysed their metadata to see if they were the same, which they were (and still ama linked).  Is this a bug that's causing random clips to turn yellow or could there potentially be a problem I'm over-looking?
    Avid Media Composer 8.3.1 Macbook Pro (Retina, 15-inch, Mid 2014) 2.8 GHz Intel Core i7, 16GB Ram Mac, OS 10.10.2 [view my complete system specs]
  • Mon, May 13 2013 12:28 PM In reply to
    Re: HD/SD yellow-coloured clips in timeline of AMA project?
    Have you changed the project format? Using HD clips in an SD timeline will show them as yellow.
  • Mon, May 13 2013 1:54 PM In reply to
    • S.Clements
    • Posts 809
    • Points 10,720
    Pat Horridge:
    Thanks, Pat.  No I haven't changed the project format.
  • Mon, May 13 2013 3:34 PM In reply to
    • S.Clements
    • Posts 809
    • Points 10,720
    I think I figured out the difference.  Somehow, even though it's ama linked and was shot on the same camera, the yellow clips are in now in 601 color space, instead of 709.  I'm not sure how that happened.   I was unaware that AMA clips could become altered after the fact.    Also, I don't know if that will effect my consolidation to DNxHD 185 at the end.
  • Mon, May 13 2013 4:13 PM In reply to
    • S.Clements
    • Posts 809
    • Points 10,720
    So, this was the problem....somehow all the yellow clips got switched to 601 color space - I'm not sure how/why.  So, I had to relink to ama again and then all the color spaces switched back to 709.  Then all the yellow clip coloring disappeared from the timeline.
  • Mon, May 13 2013 4:32 PM In reply to
    601 is SD 709 is HD.
    You can't change the format of an AMA clip. It's either HD 709 or SD 601 as source. Avid can't change an AMA source file.
  • Mon, May 13 2013 4:45 PM In reply to
    • S.Clements
    • Posts 809
    • Points 10,720
    Pat Horridge:
    Good to know it can't change an AMA clip at all.  It must be some sort of bug then.
  • Mon, May 13 2013 5:48 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    S.Clements:
    Pat Horridge:
    Or a Picnic Big Smile  ......
    Tomas
