Latest post Wed, Dec 18 2013 3:51 PM by mjolnarn. 7 replies.
  • Thu, Apr 4 2013 9:12 PM
    • ugo1
    • Joined on Thu, Jul 13 2006
    • Italy
    • Posts 281
    • Points 3,915
    Edit 1080/50P video
    as recently sony and canon are starting to sell camera with resolution of 1920x1080/50P my question is: can Media composer edit this files? if yes from which version?
    regards
    Ugo
    Case: Phantek Enthoo Luxe, Motherboard: Asus Prime WS299 Sage/10G, Cpu: Core i9-10920X,Ram: 32GB Ripjaws 4, GPU: Asus Nvidia Rtx 2080 Super 8 GB, Sound... [view my complete system specs]
  • Thu, Apr 4 2013 9:26 PM In reply to
    Re: Edit 1080/50P video
    Media Composer is aimed squarely at producing outputs for Broadcast TV.
    There's no broadcasters transmitting 50P currently so it's not supported with MC currently.
    It's also why MC can't output anything bigger than HD resolutions. No 2K or 4K support because it's not a broadcast format (yet)
  • Fri, Apr 5 2013 12:18 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    Pat Horridge:
    Just to clarify Pat's answer a bit - Avid does have very clealy established workflows for 2K and 4K - it just doesn't edit them natively. Let's not forget Avid was originally designed for editing film projects.
    You can edit 1080P50 footage in Avid but only in a 1080i50 or 1080p25 project. You can get Avid to interpret these clips as 25P and hence get a 50% slowmotion end result.
    If you want a final product in 1080P50 (for what purpose I can't imagine, it would be a very "video" look) then Avid is probably not the right tool for the job. Peter Jackson did shoot the Hobbit in 48P and 3D and that was cut and conformed on Avid but of course using higher end tools as well. Plus at least most of the critics I read preferred the 24P version (not to mention wanting the movie sliced in half!). I can't tell you what workflow Jackson used but it probably was similar to 2K and 4K workflows. This article touches on it.
    http://www.onscreenasia.com/article/middle-earth-takes-on-new-dimensions/9518
    John
  • Sat, Apr 6 2013 9:56 PM In reply to
    Avids only 2K 4K workflow I know of is using DS which will do 2K and even 4K
    But DS isn't MC.
    There are some workarounds to get 50P content in but you end up slowmo footage (and that's what a lot of folk use 50P for)
    But if you intent to shoot 1080 50P and edit it to produce a 1080 50P output or greater res then I'd suggest MC isn't the tool. Your timecodes will all go wrong if you try and go that route.
  • Tue, Apr 9 2013 3:07 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    Pat Horridge:
    But DS isn't MC.
    True but you can still cut on MC (which most people do) and conform on DS or even other systems. Framerate is a different beast. We're both saying the same thing - MC is currently not the right tool for the job.
    John
  • Wed, Dec 18 2013 1:56 PM In reply to
    • Hugh Moore
    • Joined on Mon, Mar 29 2010
    • South Australia
    • Posts 44
    • Points 570
    Hope its ok to revive an old thread, but shot some 1080/50P video on my Sony Nex 6 while trekking in Nepal.
    Have discovered that was a mistake with AVID 6 im using, so using Squeeze to convert it to 1080/25P
    Is this the simplest workflow or should I being doing something different.
    Im only a hobby shooter, so while this seems to work ok, any thoughts would be appreciated.
    Hugh
    South Australia
    MC 8.3.1 MB: Gigabyte EX58-UD5 Video: Nvidia GeForce GTX750 RAM: 12 GB Windows 10 Boot Drive: SSD Monitors: Dual User: Hobbyist [view my complete system specs]
  • Wed, Dec 18 2013 3:25 PM In reply to
    Does it work if you just AMA it into a 1080p25 project?  I've done similar with 1080p59.94 footage, in a 1080p29.97 project.  You could then transcode as needed, and it should create 1080p25 Avid media for you.
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.15.6, Avid Media Composer 2020.12 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
  • Wed, Dec 18 2013 3:51 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    usatraveler:
    This started to work with Avid 7, for Avid 6 other type of workflows are needed.
    To the previous poster, what other apps are installed on your system.
    edited ... just read that post  ok, Squeeze will do well, if you aren´t satisfied with the results play some with the settings
    Tomas
