Latest post Tue, Oct 29 2013 1:10 PM by Marianna. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Mar 28 2013 10:58 PM
    Newscutter 10.5.2.1 and 10.0.3.4 Patch Files NOW AVAILABLE
    NC 10.5.2.1 and 10.0.3.4 - Going Live! The 10.5.2.1 and 10.0.3.4 maintenance releases are now LIVE at the download center under the Avid Editor Patches link.
    Updated NVIDIA Driver NVIDIA driver version 310.90 has been qualified with this release.
    Bug UDevC00176976 The editing application has qualified NVIDIA driver v310.90. The standard configuration requires that the Global preset of the Global Settings for the NVIDIA driver be set to “3D App - Video Editing.” However, with this setting, the Marquee Title tool will not launch. If you need to use Marquee, set the Global preset to “3D App - Default Global Settings.” If you do not use Marquee, keep the Global preset set to “3D App - Video Editing.
    ReadMe Please read the attached readme file for full details.
    Patch Instructions Please read the Patch Instructions prior to installing.
  • Tue, Apr 2 2013 11:29 AM In reply to
    • Sistemes BTV
    • Joined on Thu, Oct 28 2010
    • Barcelona
    • Posts 5
    • Points 75
    Re: Newscutter 10.5.2.1 and 10.0.3.4 Patch Files NOW AVAILABLE
    It is nopt a great patch as it does not solve all the problems in the version, pe:
    - We cannot use special characters in the sequences names (when transfering with Transfer Managers it crashes)
    - There are inconsistencies when using and changing between different tools (audiomixer, capture tool, NRCS, ...) and finally we must restart the aplication.
    ISIS 7000 v.4.7.8.16090, Interplay v.3.5.0.50345, Media Indexer, Transfer Manager, Airspeed 5500, and Media Composers 8.5 on Z240, Z840, and Black Magics... [view my complete system specs]
  • Tue, Apr 2 2013 9:24 PM In reply to
    • Pixel Monkey
    • Posts 1,233
    • Points 15,560
    Hi Sistemes BTV, I think I can help you with both of those issues.
    1) Media Composer and Newscutter can use all the special characters you can throw at them, without issue. I just created a sequence called @$,.! and it works fine. But once you take Media Composer or Newscutter into a shared environment using Transfer Manager and so on, now you are leaving the perfect realm of edit software and entering the crazy land of Engineers... servers...windows networks... broken version environments and hundreds of other limitations. So it's not the editing app that yells at you about special characters but the dozens of hardware and software components in "Engineer Land" that need to work perfectly in order to insure that your file gets to air without hiccups.
    2) I'm concerned about your inconsistencies. You shouldn't be seeing those. Please create a new post in this forum and fill it with as much detail as possible about exactly what is happening. We'd love to help. Include screenshots if possible of any error messages, and even of settings. This definitely sounds like something we can fix.
    Thanks!
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
  • Mon, Apr 22 2013 4:54 PM In reply to
    • pkaszynski
    • Joined on Thu, Feb 9 2012
    • Posts 1
    • Points 15
    We have the same problem when switching between NCRS, Audiotool , Color correction etc. The most frequent problem is that NRCS freezes.If you log in to NRCS, select a story, create a bin, minimize NRCS do an edit and try to get back to NRCS the window is frozen and you can't select a different story. The only way to get NRCS back is to restart Newscutter. It is very annoying and causes frustration in our newsroom.
    10.5.2.1 fixed NRCS POST to WEB bug when it was crashing on custom templates but it didn't fix stickiness.
    Regards
    Piotr
  • Tue, Oct 29 2013 9:16 AM In reply to
    • Sistemes BTV
    • Barcelona
    • Posts 5
    • Points 75
    Hello Piotr,
    I don't know if 10.0.3.4 Patch solves the freeze windows problem.
    If not, we found that the solution is MINIMIZE that window (not close).
    When you maximize the window back,  you can continue working without restarting Newscutter !!
  • Tue, Oct 29 2013 1:10 PM In reply to
    • Posts 10,089
    • Points 216,625
    Piotr
    I do know that the 10.0.4 patch has several fixes relating to some of what you are experiencing so it is worth upgrading to it.
    the readme is here:
    http://avid.force.com/pkb/articles/en_US/readme/Media-Composer-6-0-4-Symphony-6-0-4-and-NewsCutter-10-0-4-ReadMe
    The software is on the DL center.
