Latest post Mon, Jun 3 2013 12:12 PM by bassblom. 17 replies.
  • Fri, Mar 1 2013 6:26 AM
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Capture problems "Incompatible format"
    In the past i had no problem capering from my Canon XH A1, but i build up my system again (installed everything again) Have MC 6.0.3.2 installed now, but:
    Try to start a new project but in the capture tool i get the message "Incompatible Format"and the V is gray.
    Have i missed something, a setting or something else ?
    I can see and control the Canon but thats all i can do.
    Also the tab Video say's : None
    Did a search on the forum and see the problem, but that was with version 3.5, so it must be solved by now.
    Can anybody help me...thanks in advance
    Henk
    Recom Powerstation black with Recom Pro Engine M850 Power/ Processor Intel Core i7 920,s1366 2,66Mhz QPI/ Memory = 2 x 3 x 2Gb (total 12Gb)/ 2 HD 750Gb... [view my complete system specs]
  • Fri, Mar 1 2013 6:56 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,405
    • Points 15,470
    Re: Capture problems "Incompatible format"
    Check the record format. When a new project is set to DVCProHD format and not HDV.
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Fri, Mar 1 2013 7:19 AM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Were can i find this button ?
  • Fri, Mar 1 2013 7:51 AM In reply to
    • Vilem
    • Prague
    • Posts 1,405
    • Points 15,470
    I think that must be dialed Host1394.
    V.
  • Fri, Mar 1 2013 8:07 AM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    In Res is on my screen only Incompatible format and the pull down menu is only showing that,
    so nothing else selectable, and video is showing "no Video" , so no Host1394, maybe that is the problem ?
    I have also Pinnacle Studio on my system and captering is no problem, so the 1394 port is function well
  • Fri, Mar 1 2013 8:17 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Henk, I have 5 minutes now for a skype chat
    Tomas
  • Fri, Mar 1 2013 8:19 AM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Sorry Tomas, i dont use skype
  • Fri, Mar 1 2013 9:20 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,559
    • Points 65,185
    Henk, either the project settings do not much the camera/deck output as for frame rate and size, or MC doesn't like the firewire controller, if this is a new computer; You may also try to switch the firewire driver to legacy.
    peace luca
  • Fri, Mar 1 2013 9:28 AM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Luca,
    Same computer, but installed Windows again and after that MC.
    Fire wire = IEEE 1394 Bus Host Controller ...Texas Instruments 1394 OHCI Compliant Host Controller.
    Can that be the problem ?
  • Fri, Mar 1 2013 10:38 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,559
    • Points 65,185
    Were You on MC 6.0.3.2 back at the time when the system was working fine? As of MC 5 the Texas Instruments firewire chipset is not supported anymore, at least for use with the Adrenaline and old analog/SDI Mojos, I don't know if the same applies to straight capture off the firewire port, but if this very same system properly ran the same MC version it has to work after reinstalling everything; if You're running the default Windows 7 firewire driver You'll have to switch to the legacy firewire driver: right click on My computer, select Manage, click Device (or device manager, not in front of a PC and going by memory), pick the firewire controller, right click and choose properties, select the driver tab, update driver, manual update from a list of supported stuff (or similiar), switch to the legacy driver and see if this helps.
    peace luca
  • Fri, Mar 1 2013 11:26 AM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Before (version 6.0) the system was working fine.
    Installed another (older) driver with the same result.
    looking for another driver on the internet gives always the Texas driver.
    Henk
  • Fri, Mar 1 2013 12:21 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,559
    • Points 65,185
    Henk, if the system worked before it has to work, the "Incompatible format" error message seems pretty clear, please make sure that the project settings and the output format of Your camera/deck match as for frame rate and size. Do You have multiple deck configurations by any chance?
    peace luca
  • Sat, Mar 2 2013 9:31 AM In reply to
    • Henk
    • Netherlands
    • Posts 281
    • Points 3,925
    Till now no results, but the fact that MC is controlling my camera does this not mean that fire wire is working ?
    Because i have to go on i capture the tape using Studio, but the resulting file will not be accepted by MC, so i make a AVCHD (H264) output in Studio and import this file in MC. The other files i need in this project are avchd files from another camera, so i can go on now but this was not the intension when decided to clean my system and install the newest version of MC.
    UPDATE: I imported the H264 file but  when try to import the only available Vidoe Resolution in the pull down menu are DNxHD 444 365X MXF and 1:1 10b RGB MXF.  For me total strange, also the imported video is playing stuttering, so there is something wrong with my project settings ? Anybody knows this ?
    If anybody gets a brainwave about this item...please let me know.
    have a good weekend,
    Henk
  • Sat, Mar 2 2013 10:06 AM In reply to
    • Vilem
    • Prague
    • Posts 1,405
    • Points 15,470
    I have a project that is set to RGB. Switch to a different color space. It's in the project tab used to define the details of the project. (1080i50 etc. ..)
    V.
  • Sat, Mar 2 2013 10:46 AM In reply to
    • Vilem
    • Prague
    • Posts 1,405
    • Points 15,470
    Arguably, the color space is related to the original problem.
    V.
