Latest post Sat, Mar 23 2013 6:30 PM by mrmikster. 10 replies.
Page 1 of 1 (11 items)
  • Wed, Feb 27 2013 2:05 PM
    • Aratalas
    • Joined on Wed, Aug 31 2011
    • Brazil
    • Posts 5
    • Points 75
    How to create a Lut File.
    Hi
    We are recording with the Sony Camera F65, and i would like to know how should i export the lut file from the camera to work properly on DS.
    Theres any model of the export file that someone could send me??
    Does anyone have ever worked with any workflow with this camera and could explain how it work?? Since Ds cant recognize those files natively  the only way i see is to convert to dpx..
  • Fri, Mar 1 2013 10:05 PM In reply to
    Re: How to create a Lut File.
    I have had success with Speedgrade formatted 3D LUTs.
    Igor Ridanovic
    www.HDhead.com
  • Mon, Mar 4 2013 4:54 PM In reply to
    • Aratalas
    • Brazil
    • Posts 5
    • Points 75
    How can i create it with speedgrade??
    Have you done it with the F65??
    thanks
  • Wed, Mar 6 2013 9:55 PM In reply to
    Not necessarily with Speedgrade, but as if you're making a LUT for Speedgrade. I think I did that on Alexa webpage usign their online tools, but have not done it for F65.
    Igor Ridanovic
    www.HDhead.com
  • Thu, Mar 7 2013 5:36 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 572
    • Points 6,450
    • Moderator: Avid DS
      Moderator: MetaFuze
    I've used the Arri Lut builder to create a lut for F65 to Rec 709, I'll see if I can look it up. What color space are you working in? You could probably use Resolve, Scratch or Baselight etc, to create DPX, ProRes, DnxHD etc. What resolution do you want to work at?
    Are you using the SR, or light format?
    "There are no rules for the brave". Albert Einstein
  • Sat, Mar 9 2013 2:50 AM In reply to
    • Aratalas
    • Brazil
    • Posts 5
    • Points 75
    mrmikster
    Actually i just would like to know the best way to create this LUT file, is that Arri Lut building a freeware?? My Color space is YCbCR 422 and the codec is the 44mbits i think its mpeg4SStp, I have tried to export DPX files using Scratch but it didnt worked in DS, looks like its something with that DPX that i exported i think....
    thanks for the help
  • Sat, Mar 9 2013 3:32 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 572
    • Points 6,450
      Moderator: MetaFuze
    Yes the Arri lut builder is a free service on the Arri website. Just Google it and you'll find it. Make sure you use either the Dailies or Post Production tab. The Onset gives you less options.
    When you say didn't work, do you mean it wouldn't import or looked wrong? Can you send me a single frame to look at? How does the same DPX look pulled back into Scratch?
  • Sun, Mar 10 2013 11:29 PM In reply to
    • Aratalas
    • Brazil
    • Posts 5
    • Points 75
    In Scratch it looks fine, but i think is that because it s a DPX model 1.0....Could you give me your mail so i can send it to you?? THanks
  • Wed, Mar 13 2013 5:31 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 572
    • Points 6,450
      Moderator: MetaFuze
    mforrest@postboxpost.com
  • Tue, Mar 19 2013 6:29 PM In reply to
    • Aratalas
    • Brazil
    • Posts 5
    • Points 75
    I have sent to you the DPX file, thanks
  • Sat, Mar 23 2013 6:30 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 572
    • Points 6,450
      Moderator: MetaFuze
    Just saw your email. I'll have a look.
