Latest post Sat, Jun 30 2018 2:47 PM by Telegram!. 41 replies.
Page 3 of 3 (42 items) < Previous 1 2 3
  • Wed, May 17 2017 9:11 AM In reply to
    Re: Media Composer Transfer modes/Layer blending
    Is it Groundhog day?
    +1
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona 3. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 14GB ram Aja I/O express, Apple... [view my complete system specs]
  • Wed, May 17 2017 9:14 AM In reply to
    Maybe they'll put it in Media Composer | First.. Ahahahah.. It would be ridiculous.
  • Wed, May 17 2017 2:23 PM In reply to
    • Atomike
    • Nebraska
    • Posts 712
    • Points 10,850
    Tommy Mendhoza:
    I think this is right. I mean, nobody would introduce an editor today that doesn't have this feature, no matter how inexpensive or non-professional. It's just a basic feature.  Avid First will be ignored and laughed off the stage if it doesn't have this basic, basic feature. It would be like not being able to add transitions.
    That being said, Media Composer will likely not have this feature until 2019 or longer based on the roadmap from NAB.
    Media Composer 8.X (usually newest release), Avid matrix-recommended versions of both Nvidia driver and Quicktime, Matrox Mini MX02, Self-built machine... [view my complete system specs]
    I spend most of my time between New York and Los Angeles.  In Nebraska.
  • Wed, Jan 3 2018 7:55 PM In reply to
    • dmehalik
    • Joined on Wed, Jun 10 2015
    • Posts 20
    • Points 240
  • Mon, Jan 8 2018 9:28 AM In reply to
    • Leckerwurstbrot
    • Joined on Wed, Dec 6 2017
    • Frankfurt am Main, Germany
    • Posts 8
    • Points 120
    +1
    Mac Pro 10.12.6, 2 x 2,66 GHz 6-Core Intel Xeon, 24 GB 1333 MHz DDR3, NVIDIA Quadro K4000 3071 MB [view my complete system specs]
  • Wed, Jun 6 2018 5:43 AM In reply to
    • frediko
    • Joined on Sat, Sep 27 2008
    • Norway
    • Posts 71
    • Points 950
    +1
    So. Avid FX and the cheapest plugin for this, RED, are both End of Life. MC 2018+ kind of ustable with these old plugins. This now becomes a 1000$ feature to pull off. Continuum/Sapphire to do blending? Having 30 machines do that will not happen. Doing flares and other overlays on TV-shows only in online is not happening. So the struggle is to stay at some kind of Avid MC version that still supports Avid FX but still supports enough new file-formats until this feature arrives. 8.6.5 stable for now.
    The "Avid is NLE, not for finishing" is getting really old. With that argument, You could say edit in Avid, do dissolves in After Effects. Blending modes is not an effect, it's as basic as changing transparancy, size, position of a segment.
    https://en.wikipedia.org/wiki/Blend_modes
    Could it be possible to crowdfund someone to do a 64-bit version of the dmn transfer plugin? :)
    Tried using Fusion Connect to do this, which works but is a hell of a workaround. Not suitable for multi-user environments.
    Mostly hp z420/440 on Media Composer 8.x and Symphony 8.x Also Dell Precision m3800 | Win 10 | 16GB memory | Quadro k1100 [view my complete system specs]
  • Thu, Jun 28 2018 10:53 PM In reply to
    • MrMudd
    • Joined on Wed, Oct 19 2011
    • Posts 8
    • Points 100
    +1
    Premiere user here, trying to learn about AVID. How on earth are there no blending options? I use this effect all the time...very annoying. I am not going waste 1000$ on third party software, for an effect that every other NLE is using. Very unprofessional
  • Thu, Jun 28 2018 11:08 PM In reply to
    • MrMudd
    • Posts 8
    • Points 100
    Wow, I just saw this thread was started 5 years ago...how was this requested 5 years ago and nothing has changed?
  • Fri, Jun 29 2018 11:44 AM In reply to
    frediko:
    Very interesting... thanks. I'm sure there's alot to it. I noticed that in my FX palette, I have something called "Light Leaks" from IGNITE FX. Also, Glow and Light Streak FX which include that whole long list of modes: Add, Burn, Dodge, Difference, Hardlight, Multiplt, etc. Plus lots of Boris-like tweakables, at low cost.
  • Sat, Jun 30 2018 1:41 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,353
    • Points 96,635
    I'm surprised that it's something that Avid seem unable to do.  I've written a series of effects for another edit system, and it isn't that hard.  The algorithms are out there, and reasonably well known.  I'll make a present of "Screen" to you, Avid devs.  Add the foreground to the background, subtract the foreground multiplied by the background from that, and limit the result to the range you need.
    That wasn't hard, was it?  Expressed as C-like operation, it is ret = clamp (Fgd + Bgd - (Fgd * Bgd), BLACK, WHITE), where BLACK and WHITE are as defined for your effects engine.
    Now go to it!
  • Sat, Jun 30 2018 2:02 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,218
    • Points 39,070
    This is probably a waste of a message, but would it be realistic to do a Kickstarter to develop an AVX plugin for this?
    I imagine a price point of $20 (?) would generate a resonable return for a developer, given the monopoly currently enjoyed by Boris.
    Jef
    Avid DS 11.0.2 R.I.P | MC 8.5.3 / 8.9.4 | OS 10.11.x - various MacPro Towers - home system MacPro Dual 2.8 8core GTX680 "Harpertown" QT 10.0... [view my complete system specs]
    Jef Huey
  • Sat, Jun 30 2018 2:47 PM In reply to
    20 clams, sure but I’m looking at that Wiki link, I’m looking at the set of MC-capable giveaway AVX Ignite FX that I got a couple years ago, and I am asking any of the editors that need and use these blending modes— what exactly are they used for mostly? Is it for transitions like “Light Leaks”, or is it much more than that?
    What is the difference between that free DMN AVX plugin that I sort of remember from yesteryear vs.  the new FREE Ignite FX plugins available on their site, (or the non-free sale-priced approx, $150 U.S. full version)?
    I don’t know how these blending modes are used in other NLEs, but it sure seems like some of the Ignite FX, which as I have seen on my own system have at least two in their Light FX category which make use of the same blending mode concepts (i.e. Add, Substract, Diffetence, etc. etc,) is aiming in this direction.
