Latest post Fri, Jan 11 2013 9:14 PM by Ariellek13. 0 replies.
Page 1 of 1 (1 items)
  • Fri, Jan 11 2013 9:14 PM
    • Ariellek13
    • Joined on Fri, Jan 11 2013
    • Posts 1
    • Points 10
    60 fps back to 24 fps to play regular speed
    I shot footage on a Canon 60D at 60 fps. I've decided that I'd like one particular clip to play back at normal speed (23.97fps).
    I ran all my footage through cinema tools to acheive the slow motion look. I still have the original raw files.
    My project is 23.97. I've linked the original clip (that was not adjusted using cinema tools) via AMA then transcoded it to my editing codec (DNxHD 36). The footage now plays at normal speed without a green dot in the sequence, indicating there is no speed adjustment. The clips appears to play smooth but I'm editing in low-res. Is there a better way to get 60fps to play at 24fps at normal speed?
    Thanks for the help!
